Steering wheel remount???
I am reinstalling an after market dino steering wheel(PO) that I had removed to redo some things in the dash. My question is what clocking position should the turn signal canceling do- dad be at?? I marked were it was but when installed before it would only cancel one direction and can't remeber where that was. The PO had this screwed up along with just about everything else. I do not have a factory wheel or I would look at that. Any help??
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
My Sparco wheel/Momo adapter has a mark that shows which direction should point "up" if I remember correctly. Maybe yours has something similar?
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
I tought it was 9:00. If not that, ceratainly 3:00. But, that doesn't strike a chord with me, so I say try 9:00.
Thanks I will try that..
It's at 9:00 where the turn signal lever is. Also to play it safe don't tighten the bolt all the way down on the hub until you move the car down the driveway or street a little bit to ensure the wheel is on the spline correctly, it may be off a tooth left or right. Just bring the ratchet with you and when your sure it's straight tighten it up.
68 911L |
