vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Factory Cab Roll Bar?
Anybody out there put the factory cab roll car into an '83? According to the guy I am considering purchasing one from there is a bracket behind the panel in the back where the speakers are that the factory bar bolts into. I need to check my car when I get home to see if my '83 has this bracket, but wanted to check the board to see if anybody else out there has any experience with this set-up?
PS: This bar has different bolt-in locatations that the Das roll bar.
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 10-15-2004, 12:40 PM
911SCfanatic's Avatar
Interested in seeing the install. Keep us posted along the way.
Bill G.
'68 911 Ossi Blue coupe
Old 10-15-2004, 12:55 PM
Check out this forum. There are some pretty good pictures of the locations. Good luck.
Mystery Bracket
Sean
'77 911S Cab Conversion
Old 10-15-2004, 12:57 PM
vesnyder's Avatar
Sean - Thanks. Making progress figuring this thing out, but can't fully visualize how this bolts in?
Here are two photos/schematics that I am trying to understand - Any assistance is appreciated??
Vance
Old 10-20-2004, 09:11 AM
North Coast Cab's Avatar
If its a factory item you should be able to get the part # and search that way.
John
1985.5 944 GTS
Old 10-20-2004, 09:21 AM
vesnyder's Avatar
The factory PN is OEM 911 565 907 61. Where do you search?
Vance
Old 10-20-2004, 09:36 AM
RETIRED
Joe Bob's Avatar
I looked for one a few years ago....all gone unless you find one used. I had one built....
2012 ML350 3.0 Turbo Diesel
Old 10-20-2004, 09:41 AM
Hmmm. I was at a local Porsche mechanic back in March and he showed me an OEM bar that he was about to install into an '86 cab. I believe it looked like brushed chrome. I remember seeing a Porsche part number on it.
Bill G.
Old 10-20-2004, 10:11 AM
OCD project capitan
BigD9146gt's Avatar
I have built both welded in and bolt in cages, for the life of me i cannot find a single picture of the bolt in. The cage you showed above looks like something that comes from a factory prep'd car. A buddy of mine has a '60 356 Carrera with the 4 cam engine, aluminum hoods and doors, factory roll cage, lets just leave it at "the car is amazing". The factory roll bar mounts on tubing thats installed on the car during production. The bottom inside of the boxed frame rails get an extra plate on them, then a short tube welded to the plate with a hole cut out above the top section of the boxed frame. It sticks out about 2 inches, which the roll bar then slides on to and bolts to, and the diagonal braces bolt to the back seat hinge recepticals. Its a possibility that your roll bar is that kind of setup.
Don Welch
'73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper.
Old 10-20-2004, 04:35 PM
RETIRED
Joe Bob's Avatar
They call that New Old Stock (NOS)....somebody kept that in a closet....not like you could order it from a microfiche....
Old 10-20-2004, 05:01 PM
