Home of the Whopper
T vs E mfi
Hello!
Besides the space cam in the mechanical MFI pump, are there any other differences in T vs. E MFI systems? Stack diameters, throttle bodies, etc.. Thanks! BK |
Bandwidth AbUser
Brian, this is a good thread to answer your questions:
MFI Induction Chart
Jim R. |
Yes: The intake runners in the heads, the throttle bodies, the intake stacks, distributor curve, and of course the camshafts. The P&Cs are different resulting in different compression ratio.
In a 2.0 there is a difference in valve size. In a 2.0T and 2.2T the crankshaft is cast and without counterweights. There is also the color of the fan shroud. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Home of the Whopper
Awesome! That's what I needed. But now I am confused a little. I would think 2. and 3. should be the same dimension, as should 4. and 5. If not you have a 'step' in the intake path.
1. Top opening of stack 2. Bottom opening of stack 3. Top opening of throttle body 4. Bottom opening of throttle body 5. Cylinder intake port. This shows the flow pattern going down into the cylinder. Year..69'.......70/71'.....72/73' T 1.......n/a........n/a......35mm 2.......n/a........n/a......32mm 3.......n/a........n/a......38mm 4.......n/a........n/a......29mm 5.......n/a........n/a......29mm E 1.......39mm....38mm....38mm 2.......35mm....35mm....35mm 3.......38mm....38mm....38mm 4.......32mm....32mm....32mm 5.......32mm....32mm....32mm
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S |
Stressed Member
Yes, there is a "step." All of the throttle plates (T,E, and S) are the same size, so steps are required to provide the various intake track diameters. Notice, however, that "4" and "5" always match.
-Scott
'70 911E short stroke 2.5 MFI. Sold ![]() ![]() ![]() '56 Cliff May Prefab |
This may be obvious, but the US 911T only had MFI on the 2.4L engines for '72 and part of '73. Elsewhere they remained carburetted.
Brian '73 Carrera RS '71 911S coupe 'Patrick' '16 Cayman GT4 '91 C4 coupe Last edited by fryardds; 10-20-2004 at 08:35 AM.. |
Waynes' rebuild book (pg. 201) indicates both the intake and exhaust ports are the same for the T and E 2.4. Is this correct or a typo? can anybody confirm.
Thanks, Joe |
If I remember correctly T's and E's had the same exhaust port size (32mm) and they had the same distributor curve. The 2.2.s and 2.0's had different ignition curves as did the 2.7RS, but the 2.4T, E and S all used the same ignition curve.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Is there any visual way of knowing what curve you have installed? I know that you could measure it, but was curious if there was a visual color identifier in the distributor. I have an engine built to like RS spec, and was curious to verify ignition changes. It does have the higher rev limits installed.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
