rubber drip vent tube
I'm looking for the dingus that hangs down from the front turn signal housings (on a '73). At least my care has empty holes there, just like on the rear turn signals and the front trunk area.
In the latter two areas, there are rubber tubes that go in the holes and then flatten out. I can't find them in the catalog search engine -- but I did find something for the late 1980's cars in the headlights. IS that what I want? Thx. http://www.pelicanparts.com/catalog/images/lamps/diag/drain.jpg |
Yes, that is the part you need. It is part #141.941.147. However, you should have them in your (`73) headlight buckets as well. It is the same part # for both the headlight bucket drain, and the front signal housing drain.
