-   -   Rookie question for not so rookie P-guy (http://forums.pelicanparts.com/porsche-911-technical-forum/188447-rookie-question-not-so-rookie-p-guy.html)
geof33 10-21-2004 09:54 PM
What colors are the fuses to amps??? I can't see the amp #'s on the yellow ones... Anyone know the list? :confused:
MartiniRacer 10-21-2004 10:02 PM
Color and Current Ratings for Maxi Fuses
Yellow
20 amps
Green
30 amps
Amber
40 amps
Red
50 amps
Blue
60 amps
Brown
70 amps
Clear
80 amps
Color and Current Ratings for Mini and Standard Fuses
Violet
3 amps
Tan
5 amps
Brown
7.5 amps
Red
10 amps
Blue
15 amps
Yellow
20 amps
Clear
25 amps
Green
30 amps
SmileWavy
geof33 10-21-2004 10:06 PM
Cool... Thanks!!http://www.pelicanparts.com/support/smileys/wat6.gif
Jim Sims 10-22-2004 04:41 AM
The above color codes are NOT CORRECT for the fuses used in many 911's. I'm referring to the pill shaped plastic or ceramic fuses with the metal fusing element exposed on one side on the outside of the fuse body. The correct code is: 5amp yellow; 8amp white; 16amp red and 25amp blue. Jim
Rot 911 10-22-2004 04:59 AM
WHAT JIM SIMS SAID IS CORRECT!!!!!!!!!!!! (And yes, I meant to shout)
geof33 10-22-2004 06:28 AM
I thought that was a little strange. And was trying to figure out what "mega" fuses were...
The others were more on the line of what I thought.
Thanks guys...
MartiniRacer 10-22-2004 06:42 AM
Sorry Guys :( this showed up at a google search i hope no harm is done.
Wil Ferch 10-22-2004 06:46 AM
Martin...
Your answer ( be careful next time please !).....still has some benefit to the later 911's.....such as 964/993 application.
The fuses you refer-to are horseshoe-shaped..aka ATO ( also known as "US" style) type fuses.
Cheers,
Wil
geof33 10-22-2004 06:53 AM
Is there any place the panel is laid out in a pic with all of the correct amperages for the box. I don't think any are incorrect, but I'm redoing the panel with newer fuses to get rid of the old POS plastic ones...
I have a Hayes manual, but I don't recall a fuse list. I need to get a Bentley's... So no flames for that one!!!:D
Wil Ferch 10-22-2004 06:59 AM
They are very model year-specific, even cars within a given range ( like the 84-89 Carrera 3.2 series.)
I would use a combo of Bentley, Factory manuals, and a "known" similar model for comparison. When unsure of two different answers...use the lower Amp rating and check deeper.
Wil
Jim Sims 10-22-2004 07:03 AM
"Is there any place the panel is laid out in a pic "; the car's owner's manual should have a list of the circuits with fuse ratings and there should also be a chart pasted/molded inside the fuse box cover identifying the circuits (but not fuse ratings). Jim
