Compression test equipment
I want to do a compression test on the SC when I change the plugs out tomorrow.
Is this a good tester to get? http://forums.pelicanparts.com/uploa...1098515506.jpg http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00 947089000&tab=spe#tablink I don't know much about them- is it difficult to secure the hose end in the 911 plug holes? It looks as if it doesn't actually screw into the hole- is this bad? Will I be ok cranking the optima for this task (I don't own a battery charger?) Thanks. |
That tool looks fancy. I think a one piece hose would work the best cause of how deep the holes are. Your batt should be fine for the test.
Dean |
Yes, it is good, that is the latest model of the one I have. The screw in rather than press in plug fitting is the only way to go.
| All times are GMT -8. The time now is 02:01 AM. |
