torsion bar creaking
we just a little bit of rain and my front end is creaking something horrible! is there a quick fix until I can get to mt mechanic?
Old 10-25-2004, 02:54 PM
Chuck Moreland's Avatar
What kind of bushings do you have up front?
Chuck Moreland - elephantracing.com - vonnen.com
Old 10-25-2004, 03:01 PM
Sorry, I have no idea. I was told they don't wear out??
Old 10-25-2004, 03:02 PM
PRO Motorsports
Tyson Schmidt's Avatar
The stock rubber bushings sag, and this allows the torsion bar to rub on the I.D. of the control arm.
Some Elephant Racing poly-bronze bushings are the way to go. Otherwise, you have to replace the control arms to get new rubber, since they are vulcanized to the arms. I don't recommend the poly-graphite bushings, since they are too much work to re-grease, and will seize if not lubed periodically.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 10-25-2004, 03:05 PM
This is what 15 year old stock rubber a-arm bushings look like
Although they have to wear a lot more before they'd start making noises...
Polygraphite replacement bushings can squeel like a pig if they run out of grease (and even with grease they can be nasty)
Parts that don't wear out still need to be invented
Old 10-25-2004, 03:11 PM
thanks. I'm going to go kick my mechanic in the nuts!
Old 10-25-2004, 03:14 PM
