Kurt: Are you still happy with this resistor setup? I just got my motor back in last weekend with a lot of factory stuff gone! I installed Thom's fiberglass piece, and with my blower gone, the footwells don't work. I plugged the main blower in to verify, and they did work when it was in the circuit. So, your idea sounds great in order to keep the footwells going (which move more air to the cabin IMO).
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
I am going to backdate the heat on my 84. Just wondering if this set up with the ceramic ballast held up with the test of time?
Doug 1984 Carrera Coupe |
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
Kurt, thanks for the info, much appreciated!
What Kurt said, it worked like a charm!!
Here's another approach to getting the footwell blowers working.
Carrera - Removing Engine Compartment Heater Blower
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
little help?
can someone tell me the difffernece between #4 and #5 in this pic? Are they the same or not? The description is very similar:
#4) 930.106.321.01 Hot air socket, steel #5) 911.106.327.00 Hot air socket
$35 and a six pack to my name..... '88 Diamond Blue Carrera CE 3.4-SOLD
Now that I deleted all the HVAC plumbing from my car (well almost all) I have the blowers wired to toggle switch. I use the factory resistor above the glove box to control speed. It is a 3 position toggle, so middle is off, up is low speed and down is full speed. Works great, but this solution is not for everyone.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
An alternative setup is this type from pre 1975 cars: ![]() Here is an SC car with pre-75 setup: ![]() If you have a Carrera car you should use the Part #4 (in your original post) for the left side as this part will clear the Ignition Distributer. The pre-75 left side tin needs to be modified a bit to fit in the Carrrera. If you have AC in the car it makes things harder for the backdate, the pre-75 right hand tin will NOT fit under the AC Compressor. Not sure if the Turbo tin fits? I'm working on modification to the stock Carrera right block-off tin so that it can have a duct attached to it and fit under the AC Compressor, I'll take some pics and post them soon. The modification costs about $5.00 for a simple 2" PVC elbow and some epoxy, does not look 100% great but who cares it's going to be covered by the AC bracket anyway.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 05-05-2008 at 05:40 PM.. |
scarceller,
Thanks for clarifying. I thought you could the Turbo version so you did not have to modify (bang with hammer) the pre-75 set up. I am lookimng to keep my stoick exchangers for now and remove the engine blower. For a $100 dollar part, a hose and a few clamps its a great mod.
Good luck
See this link for a few ideas on doing the LHS duck so you can still use the AC Compressor and bracket
Need help on backdating heater
