-   -   How do you open a longhood that has an improperly adjusted latch? (http://forums.pelicanparts.com/porsche-911-technical-forum/188863-how-do-you-open-longhood-has-improperly-adjusted-latch.html)
crashmy911 10-26-2004 05:10 PM
Can opener!
Sorry couldn't resist!
stormcrow 10-26-2004 05:25 PM
John,
As it was stated above, have someone press down on the front of the hood by the latch and pull the handle. By pressing down, you are taking pressure off the latch and it should release the hood.
If this doesn't work the you will probably have to move on to the next step to access it.
"A Porsche does more then just go fast in a straight line"
Elombard 10-27-2004 05:40 AM
Yah I am going to those rubber thingies, I am sick of it!
deoxford 10-27-2004 06:18 AM
John,
I have had this prouble with my car before, I used a thin wire and fished it under the hood .
Then got both ends of the wire on each side of the latch
Then I just pulled towards me, Open !!
