leaking floor jack
My floor jack lost most of its fluid so I went to Kragen to find some more. The sales people there had no idea what to sell me and I have no idea what type of fluid is in that thing. Can you help? Thanks.
My old jack started leaking and I found a bottle labelled "hydraulic jack oil" at my one of my local Auto Parts stores. Call a few, one of them will have it. Failing that, go to an industrial hose/filter shop.
Sears sells it. It is hydraulic jack oil, IIRC.
'86 911 targa '04 MB 230K Sport (daily) |
Although this is not an endorsement, My cherry-picker was leaking when I was taking the 2.2 w/trans out of the truck. I was PO's at Murphy (law), I grabbed a bottle of power steering fluid and did a refill. Seemed to hold (thank God), as I lifted the everything completely onto a steel table. Scared the **** out of me when the chain slipped a litte.........
923/912E (2.1l OEM EFI ![]() '99 F150 4x4 Chipped (who cares) LLVL in the LBC... "Long Hoods Rule" "RICE - The Breakfast of Champions" |
Guest
Posts: n/a
I used auto trans fluid on my 8-ton hoist. Worked fine and is back to normal. I think that either AT Fluid or PS Fluid would work just fine.
I've been using ATF for years.
Thanks guys. I bought hydraulic jack fluid at Pep-Boys tonight.
Chris,
Why did it leak? Could be a bad seal and therefore an unsafe tool.
Warren & Ron, may you rest in Peace. |
You do not have permissi
A $100 jack gives a lot more peace of mind than a flattened ribcage or a bent suspension.
Meanwhile other things are still happening. |
Good point. The seal around the fill plug is intact but the plug itself was loose. I've used it since refilling and it seems to work OK, no leaks. I don't crawl around under the car when it's only supported by a jack so I think it's OK. Thanks for the tip though.
