for island911
I see you are about - are you still selling "the tool?"
It's the Brake Pad Warning Light. If the light stays on when the engine is running the brake pads are worn excessively.
Gotta really measure the voltage at the battery.
Dan |
Don't be so hard on yourself. DUMB is spending $400 on a new alternator and THEN realizing the error.
And I'm willing to bet that you aren't the only one who's gotten the lights mixed up. On my '88 I had brake pads without a slot, so I just hooked up the sensor wire and zip-tied it to the cable. Gotta remember to check the pads, though. |
"Gotta really measure the voltage at the battery."
And the voltage at the rear on the fuse panel, & at the alt.light. Then make conclusions. Monster batteries draw/suck down the alt. voltage too. You need to also measure the charging current INTO the battery. |
| All times are GMT -8. The time now is 01:32 PM. |
