'70-71 911 in Virginia?
I'm in central VA and I would like to look at somebody's car for reference on the 901 clutch/tranny setup. I am at wits end. Thanks to all on here who have tried to help and for the refernces to other threads. This just isn't making sense to me and I need to actually see it on a car. I am willing to drive to D.C. if I have to. Of course the closer you are to me the better. I am just north of Charlottesville.
Thanks,
Allan
Old 10-23-2004, 09:16 AM
Send a message via ICQ to fred hannah
allen i live in greensboro nc and have a 1970 91t 2.2 w 901trans. dont know if im to far but your welcome to come by if your interested.
fred
Old 10-23-2004, 12:58 PM
Paul Thomas's Avatar
Sorry to get off topic.
Fred, where do you live? I live in Jamestown off Oakdale Rd.
Paul
My ignition is retarded.
Old 10-23-2004, 01:01 PM
paul i live at the corner of penny road and wendover ave in the nottigham development (jamestown) sounds like were close by.
fred
Old 10-23-2004, 01:04 PM
jluetjen's Avatar
FYI -- '70 and '71 cars used the 911 transmission. The '66 through '69 cars used the 901 transmissions. The primary difference (which is meaningful for you) is the clutch set-up.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 10-23-2004, 03:16 PM
Yep. That is why I specified '70 or '71.
Old 10-23-2004, 03:41 PM
Has anyone posted pictures for you? Would they help?
I have a '70 on a lift in my garage if a pic would help. What do you need to see?
Old 10-23-2004, 05:47 PM
Hey, a few pictures might do the trick. I would like a series of pictures that shows from the very end of the clutch cable up to where it goes into the bowden tube. Basically, the entire set up once it comes out of the transmission tunnel. I took my car apart almost 2 years ago and I don't have a shop manual. Anyway, it's the last piece of the puzzle and I'm ready to get it going again.
Allan
Old 10-23-2004, 07:52 PM
sprbxr's Avatar
Send a message via Yahoo to sprbxr
Call Robert at Lufteknic. www.lufteknic.com He is in Richmond and might have one in the shop you could look at. If not, I am sure he can give you the info you need.
Justin
Old 10-23-2004, 09:05 PM
By the way, I would like to thank Fred for the offer. $ hours away might be pushing it. Lol
I'm hoping the forthcoming pictures will do the trick.
sprbxr - I have just recently found that website. Looks like a pretty good shop from what I can tell. How long has it been in Richmond? I used top live there and it sure wasn't there then - god knows I looked high and low for somebody to work on my old 356 and could find only one guy.
Old 10-24-2004, 07:58 AM
Pretty greasy but hope these will help. I only now realize how much more complex the system is than on the 65-69 car. There are 3.
Old 10-24-2004, 09:44 AM
#2
Old 10-24-2004, 09:48 AM
#3 If you need a different angle, let me know. Hard to get much at the firewall end.
Old 10-24-2004, 09:49 AM
A little knowledge is dangerous, but here's what I think I know.
Your frustration may be caused by the fact that you are dealing with a "push" clutch, unlike the "pull" system of the earlier cars.
The lever in the picture is pushed toward the rear of the car when the pedal is depressed. It is anchored to the bracket at the far rear (pic 3). Adjustment is accomplished with the two large nuts which provide fore-aft adjustement relative to the "hole" (pic 2) which the housing passes through. Also, I believe it is important that the housing "floats" midway in the "J" bracket as shown in pic #1.
It moves down when the pedal is depressed and, if it is restricted by the bracket, the clutch will not fully disengage.
Old 10-24-2004, 10:45 AM
Thanks a lot. BIG HELP. I'll let you know how it goes. Maybe I'll post some picks of the old girl since I haven't ever done that. It's nothing special as far as models go but t's special to me.
Old 10-24-2004, 01:46 PM
WOOHOOO! I drove it home tonight. It's idleing a little high, but it's back on the road.
Thanks for all the help guys. The pictures showed me the stupid thing I was doing wrong. Thansk a lot Jim.
Allan
Old 10-26-2004, 07:09 PM
Good to hear you got it together and glad to help.
Old 10-26-2004, 08:47 PM
Now if you really want to improve your shifting, replace the 901 shifter with a 915 shifter + factory short-shift kit! You won't believe how good it will feel.
JohnH
'87 Carrera
Old 10-27-2004, 01:05 PM
