SC Fan Belt -- 710 or 725
Is there a quick indicator or measurement I can make to determine if my SC engine uses a 710mm belt or 725mm belt? What causes the difference, e.g., size of the crank pulley, outer half of the fan pulley, ??? BTW, during my engine rebuild, I have found some parts to be 78-79 vintage and other parts to be 80-83 vintage. Thanks, Duane
'79 911SC Targa -- "BLUVUDU"
'83 930 Coupe -- "TURBAUX"
Old 10-29-2004, 06:27 AM
Do a search on "Fans" or fan-pulleys or my name...it's been discussed and there are differences based on both crank and fan pulley diameter differences.
Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 10-29-2004, 06:48 AM
Somatic Negative Optimist
Gunter's Avatar
Both are good vintage. Make sure that you follow the correct procedure and use the right tools. There are quite a few DIY's who did a sloppy job, wrecking the shaft where the pulley is mounted, or damaging the fan by sticking something into the fan blades to hold it back. $$$
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 10-29-2004, 08:36 AM
Here's one example.....
bottom of pg 1 ...my post ...
Engine Fan Drive Ratio
Wil
Wil Ferch
Old 10-29-2004, 09:43 AM
