Doug E's Avatar
Pictues of Drilled SC Airboxes?
Anyone have pictures of their drilled SC airboxes?
Before I go using a hole saw on mine I wanted to get a few ideas of how others have done it. Also wanted to get a feel for the different sized holes that are used.
TIA.
Doug
'81 SC Coupe
Old 10-30-2004, 05:52 PM
Hilbilly Deluxe
emcon5's Avatar
Why?
82 911SC Coupe
GTI Cup #43
Old 10-30-2004, 07:20 PM
Designer King
Paulporsche's Avatar
If you search this you will find that the feeling seems to be that there is no performance gain from this. Some however do prefer the change in induction sound, although there is greater risk of water entering the airbox. Instead some have cut off the horn and opened up both ends of the cover.
Having said this, I think you will find that those who do it are using 2 or 2 1/2" hole saws to make their openings.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-30-2004, 08:38 PM
Do yourself a favor and pick up a used airbox cover so that you can go back to stock if you don't like the change or make a mess of the original cover. I drilled out an airbox cover and I love the sound. No real power gain, but when the engine goes on cam it sounds like a 993 when the varioram kicks in.
Old 10-30-2004, 08:49 PM
Doug E's Avatar
Here's some more info:
I should have clarified and said that I will be doing this on a spare cover.
At the last DE my instructor drove an '80 SC and he said he felt like it was worth something coming out of a few turns on our home track so I figured what the heck, I'll give it a try.
For the next DE I am going to take both covers and alternate sessions to see if I can notice a difference.
I figure there has to be an optimal pattern/size so I just was looking to see what others had done so I had a few ideas before I went and cut up the spare.
Any pictures and additional first hand info would still be welcomed.
Thanks again.
Doug
'81 SC Coupe
Old 10-31-2004, 05:13 AM
poorsha's Avatar
Old 10-31-2004, 07:05 AM
For track use, why not try what the Ducati guys do, and run an "open" cover? What you do is just use some wire or straps to hold the air filter down - don't use a cover at all.
Old 10-31-2004, 07:33 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
It's mainly for the change in sound, no power gain. But i do like the sound, and i did mine by triangulating three holes on the opposite side of the horn, then using a jigsaw to open an oval shaped hole. I don't have any pictures of it off hand, but i'm sure you can picture this in your head.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 10-31-2004, 08:25 AM
Registered abUser
TerryH's Avatar
Originally posted by poorsha
Why bother with a cover at all? Wrap one piece of duct tape around the center to hold the filter and call it good.
All those holes look cheesy.... swiss even.
'81 911SC Coupe SOLD
Old 10-31-2004, 09:00 AM
What?
trj911's Avatar
The only thing the holes are good for is sound. To have more air come in, the air must have some way to get out. You have to change the exhaust to improve power.
Tom J.
911SC Cab
SCWDP
CaymanS
Old 10-31-2004, 09:06 AM
jmshepard's Avatar
I drilled one big hole for the track.
Old 10-31-2004, 09:08 AM
hkspwrsche's Avatar
I only put one hole on the end opposite of the air horn (right side) same size as the hole I put in the lower for the popoff valve. I used an unscientific way of determining if it needed more air.
Put one hand over the opening and felt how much pull it had and decided if I put it on the right side it wouldnt have any more chance of getting water that the left. Plus any more holes than it needs and it starts to lose torque on the bottom end(moves the peak hp further up the rev range). Also have a low restriction exhaust..testpipe... richen fuel...I'll post a pic later when I get a chance.
Harold
Old 10-31-2004, 09:12 AM
Registered abUser
TerryH's Avatar
hey! Where did you find that rectangularly large drill bit?
Old 10-31-2004, 09:15 AM
autoxracer31's Avatar
Send a message via AIM to autoxracer31
watch out for the rainy season
Old 10-31-2004, 11:43 AM
klaucke's Avatar
That's it I'm making one out of sheet metal. It will be open filter but have a little roof edge off the top for rain (although I never drive in it). I just put my car away for the week though, down the street. Project will have to wait.
Old 10-31-2004, 01:43 PM
