Question what's a BHKZ
the factory print shows something called a BHKZ unit , what is it ? it has something to do with the tach ,of which mine is not working , I have a 1969 911 T 2.0 engine and tach is dead , print shows the tach circuit as going to the intermediate unit {it was missing but I got one from walker } then to the coil and then to this BHKZ unit {mine is missing } as far as I can tell ,..,. any info ? thanks Rob
Old 10-17-2004, 07:46 PM
driver
porcupine911's Avatar
Batterie-Hochspannungs-Kondensator-Zündung
it is your capacitive discarge ignition unit.
- chris
Street: 1971 911E, 2007 GTI 2.0T, 2012 Cayenne Turbo, 2019 GTI TCR, 2022 Boxster 25 years
Circuit: 2020 Cayman GT4
Old 10-17-2004, 07:56 PM
thank you ,. now do I need it ? the car will start as is but the tach is still dead ??I think I need it ?Does this unit get plugged in with a 6 way molded plug by chance ? because I have one not being used now ., thanks again , Rob
1987 911 carrera targa
1969 911 T still working on this one
other oldies
1968 honda mini trail 50 ko model
free bee came in boxes
1981 CR 250 R basket case
rebuilt and running
Old 10-17-2004, 08:09 PM
Warren Hall Student
Bobboloo's Avatar
It's the CDI box (capacitive discharge unit) mounted on the left side of the engine compartment. The car won't run without it. Your tach problem is probably elsewhere. Check the lead that goes from the back of the tach to the distributor for continuity. It should be black with a purple stripe wire. Any multimeter will do.
It's probably just unhooked.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 10-17-2004, 08:28 PM
no cdi box
As far as i can tell I do not have a cdi box the only thing on the left wall is the regulater for the alternator and the ballast for the tach which I didn't have till I got one from john walker.any more help? the car does start and run 1969 911 t ,I think it's wired like an earlier model . thank you Rob
Old 10-31-2004, 05:23 PM
