Bez Bez is offline
strut damage
I'm the guy who ran over a chunk of metal on I-80 and mangled both wheels on passenger side.
After installing temp wheels, I noticed front right wheel camber is way off. I'm guessing that I bent a strut, but is it possible that there is more extensive damage?
For instance, is it possible that the mounting location at the top of the fender was damaged from the impact of the strut bottoming?
Oddly, the car drives perfectly straight with no shimmy despite the severity of the hit and the camber problem.
Old 11-01-2004, 06:25 PM
PRO Motorsports
Tyson Schmidt's Avatar
Anything is possible, but it's usually just a bent strut, tie-rod, and/or less commonly, a bent balljoint shaft or control arm.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 11-01-2004, 06:32 PM
