-   -   repair gurus , I need part # help.... (http://forums.pelicanparts.com/porsche-911-technical-forum/190222-repair-gurus-i-need-part-help.html)
audi2.7t 11-01-2004 06:51 PM
I need the part # / description for the channel that runs around the engine bay and holds the large rubber seal in place ,it seems that the morons that fixed the light r/s rear hit decided that it was easier to cut a section out than repair it......:rolleyes:
thanks ,
Sam.
Jim Sims 11-01-2004 07:05 PM
Called a rail; try 901.501.796.20 for right (passenger's side), 901.501.795.20 for left (driver's side) and 901.501.797.20 for the rear. Cheers, Jim
Bill Verburg 11-01-2004 07:08 PM
One of these pieces?
http://forums.pelicanparts.com/uploa...1099364881.jpg
Jim Sims 11-01-2004 07:19 PM
Or is it part no. 5 in the below figure?
http://forums.pelicanparts.com/uploa...1099365532.jpg
Jim
audi2.7t 11-01-2004 07:19 PM
Hmmmm ,I'm not seeing it in the pic Bill ,it's about a 1" channel and the seal actually pops into it ,this would be a cross section --> (______) , (rotate 90 degs) and it runs all the way around the inside of the engine bay .
thanks ,
Sam.
audi2.7t 11-01-2004 07:20 PM
#5....BINGO...(I think) .
Sam.
Jim Sims 11-01-2004 07:21 PM
Look in the second figure (part no. 5) which matches the part numbers I posted. Jim
audi2.7t 11-01-2004 07:24 PM
you guys are gooooooood !!! ,I'll raise a cold one to each and every one of you while I sit in my garage and contemplate turbo flares..........cheers
