-   -   How I replaced my Dash (http://forums.pelicanparts.com/porsche-911-technical-forum/190489-how-i-replaced-my-dash.html)
cicsprog 11-03-2004 08:56 AM
It’s about time I contributed something here rather than taking. In that vain, I documented the replacement of my cracked dash with an OEM one. You may remember this post:
http://forums.pelicanparts.com/porsche-911-technical-forum/189711-replacing-dash.html?highlight=dash
First, to me this is NOT an easy task. It took me a full day. My car is an 88, so there was no need to remove the windshield (applies to 86+ cars). However, once the old dash was out, putting in the new one in place proved difficult with the windshield in. However, it can be done.
First thing, steering wheel off, gauges out, defrost vent cover off, and center air vent out to access bolts that hold dash.
http://forums.pelicanparts.com/uploa...1099504533.jpg
cicsprog 11-03-2004 08:58 AM
Bolts are located at each end of the dash, two on the top of the drivers console, one on each side of the vent hole, and one midway of the glove compartment. The passenger side end bolt and the one midway of the glove compartment are the most difficult ones to get off (easy since I cut out the dash) and then secure. These are knuckle busters. A flexible LONG screwdriver that accepts 10mm socket proved invaluable.
http://forums.pelicanparts.com/uploa...1099504693.jpg
cicsprog 11-03-2004 08:59 AM
As I tried to remove the nuts from behind the gauges, they would just spin along with the bolt. The bolts are actually molded into the dash. Heat/sun had caused these to fail and access was so tight I could not hold the bolts to get the nuts off. So it was my decision to just cut the old dash out. I also had to cut off one of the bolts on the left side of the air vent with a bare hacksaw blade because it was stripped. You may want to consider this problem if you decide to redo yours by “Just Dashes”. You may end up having to buy a whole new dash. Removing the nuts became a lot easier by tearing out the dash
Failed bolts
http://forums.pelicanparts.com/uploa...1099504790.jpg
cicsprog 11-03-2004 09:02 AM
tearing dash out....what have I gotten myself into!
http://forums.pelicanparts.com/uploa...1099504922.jpg
cicsprog 11-03-2004 09:04 AM
This dash is now For Sale...any takers?
http://forums.pelicanparts.com/uploa...1099505019.jpg
Dash completely out. Take some time to do some cleaning and replace bulbs.
http://forums.pelicanparts.com/uploa...1099505063.jpg
cicsprog 11-03-2004 09:07 AM
New dash before installation
http://forums.pelicanparts.com/uploa...1099505120.jpg
Dash fitted in place
http://forums.pelicanparts.com/uploa...1099505159.jpg
Hardest bolts to secure are here on the passenger side firewall
http://forums.pelicanparts.com/uploa...1099505232.jpg
cicsprog 11-03-2004 09:10 AM
The vent plate will probably need to have the underneath foam replaced due to sun/heat break down. I used car/marine weather stripping from Home Depot. This NEEDS to be replaced, if bad, since vent cover won’t sit properly on the dash with out the foam offsetting it. You will need ½ to ¾ inch thick by ½ inch wide weather stripping to get the proper fit. Mine was ¼ inch thick with one sticky side, so I just laired it to the proper depth.
http://forums.pelicanparts.com/uploa...1099505298.jpg
Throw the toupee away
http://forums.pelicanparts.com/uploa...1099505387.jpg
Completed installation:
http://forums.pelicanparts.com/uploa...1099505407.jpg
Plavan 11-03-2004 09:10 AM
It is almost worth taking the front windshield out. It made it very simple on the race car to do it. Now we just have one of those plastic "coverlays" in place with no real dash in place. looks good.
pwd72s 11-03-2004 09:14 AM
Nice thread! How fortunate that you didn't have to pull the windshield. Good point on the "just dashes" route...be sure you have a repairable dash in hand before sending it in. Evren's path was to buy a cracked but repairable dash from a board member here, then it went off to Just Dashes. We were able to finally get it to Istanbul, where it's now awaiting the install time...
JeremyD 11-03-2004 09:17 AM
woo woo! We'll make a DIYselfer out of you yet! Looks like a great job...
I think you might need to remove this picture http://forums.pelicanparts.com/uploa...1099505019.jpg
There's a law in the great state of Florida about subjecting dashes to any cruel and unusual punishment - I believe this one got a verbal as well as phyical assault!
cicsprog 11-03-2004 09:36 AM
Six beer job if successful....12 beer if not.....would I do it again? Hum...
fitz 11-03-2004 09:48 AM
CICSProg,
What a great thread! I also have an 88 and was thinking about doing the same thing over the winter. Now I'll just follow your information to help me. I also didn't know that this could be done without taking the dash off, that's what has stopped me from doing this project.
Question, where did you buy you OEM dash from and how much did it cost ? I've seen regular black OEM dashes but haven't found any colored ones (mine is dark blue).
Thanks again for sharing this great thread...Ron Fitz:)
Randy Webb 11-03-2004 09:48 AM
The old dash is worth $85 (plus $115 shipping & "handling") on eBAY.
chuckw951 11-03-2004 11:53 AM
You know, if I did this I would get to about this point:
and my wife would walk into the garage, roll eyes, and walk back out.
Good job on getting this project done.
cicsprog 11-03-2004 12:10 PM
I must be married to the same gal.....mine does the same thing...Thanks!
cicsprog 11-03-2004 02:26 PM
Well, now you have the instructions.....now you can enjoy the fun of this project:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2498098584&catego ry=34206
Just happen to bait my hook and see this. I'd ask a lot of questions. Looks like black. Has no feedback.
Jason
88 911
DG624 05-04-2005 01:03 PM
I have a similar dash color and was going to ask Just Dashes for a replacement. I priced a factory part and it was $1,700!!!
WIll I have to remove the windshield for my '86?
How did you find a maroon replaccement...I gave up?
RickM 05-04-2005 01:09 PM
Originally posted by DG624
\How did you find a maroon replaccement...I gave up?
Just Dashes will probably recover in any factory color you'd like.
FrayAdjacent911 05-04-2005 01:16 PM
Makes me glad my dash was replaced by one of the POs. It's in good shape with no cracks... except someone painted parts of it with a maroon color, and went nuts with red in the interior. I'm going to have to remedy that during the restore... hehehe
DG624 05-04-2005 01:27 PM
Rick, have you tried Just Dashes? It is hard to buy something like interior parts mail order. I would like to know about fit, color and surface texture match. I don't want to have a to go to a black dash with a maroon interior.
I was told that temperature extremes cause cracking but can racing cause stress for the dash and create cracking also? I need to do alot of restoration with rust at suspension pickup areas so maybe that had some effect on the body flexing. I am not using the car for any racing now until it is sound.
cicsprog 05-04-2005 01:41 PM
I gave up trying to find a Burgundy dash. Believe me I looked for a long time – wrecks, EBAY, and WWW. I shelled out the $1700.00 for one of 3 remaining burgundy new OEM dashes left from the Fatherland. As the wife says “I’ll be buried in this car”.
If those screws are stripped (actually no longer imbedded in dash material) under the driver side dashboard, I’m not sure how you would ever get the dash pad out in-tacked so “Just Dashes” could recover the old. Hopefully, they have a complete replacement.
Jason
88 CAB
DG624 05-05-2005 12:24 PM
I called Just Dashes and they want $710 for a remolded vinyl dash. Still very high but better than 1,700. Can anyone say how well their dashes match (color, size and texture)? My interior needs alot of help but the doors and rear parts are fine. The seats and carpet in front are shot.
Just dashes claims their replacements are more durable than original equipment.
I also asked about a leather covered dash. That runs between $300-425 depending on the company I asked. I read on this site that leather has a bad tendency of warping the dash and was not sure if this was worth trying.
Neilk 05-05-2005 01:38 PM
If there really is a ~$1000 difference in price then I would go with Just Dashes. However, the quality isn't the same.
Check out this post this post.
randywebb 05-05-2005 01:53 PM
I asked John Walker about that - he runs a shop in C-Addled where the problem of sun exposure should be about as low as gets in the US. He said avoid, so...
use the names to search up that thread if you want to see it...
DG624 05-05-2005 03:44 PM
I use a car cover and noticed the cracks after parking the car outside of the garage for a year. It is very hard to buy mail order parts that are not factory. I would be interested in any other manufacturer.
I talked to just dashes and they said they remove the existing vinyl and foam and start over. Maybe the thickness is different on the recover. COlor match would also be critical for a maroon interior. They did have several 8 or 9 different textures for various dashes. Looking at internet pictures is like looking at a car in the rain ...they usually look perfect. I am not going to do anything immediately but I don't want to get a bad deal.
naparsei 08-24-2005 07:11 PM
Chad,
Could you elaborate on this? Preferably with pictures? I would love to see a racecar setup without the factory dash...
Also,
Who has used Just Dashes, and how good are they?
Thanks,
Alex
Crachian 08-24-2005 08:27 PM
I ran into this problem with the studs on top of the instrument nacelle. Using a very long flat screwdriver or other pry tool it is possible to pop the square, embedded end of the stud out of the dash material. Then just lift straight out. With the glass in, I suppose you would have to bend it in a large arc to pull it back between the A-pillars.
Is that your $1700 dash laying on the driveway?
