replica fuchs centercaps
I have some 15x7 five lug fuch replica wheels and need centercaps. Which ones fit? How do they attach?
I have seen some caps with small screw holes and some with retainer clips. What do I need?? I am in the process of installing my five lug items and want to find what I need before I finish up.
Mark
72 914 5.0L
http://community.webshots.com/user/marksurel
Old 11-03-2004, 02:54 PM
steve911's Avatar
Mark--
First step is to measure the opening of hole in the wheel, which will determine the type of centercap you need.
Newer (74 + on) wheels use what are commonly called ring-type center caps. The rear of the cap has a ring with 3 small 'nubs' to hold it in via friction.
Older wheels (73 + older) use 3-prong caps - there are 3 metal prongs that hold the cap in the wheel.
They are NOT interchangeable. I'm not at home at the moment, so I can't measure the respective caps.
The 2 holes in the caps are for ease of removal - I don't think they have any other use.
Check out my signature line for samples of different caps.
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 11-03-2004, 03:12 PM
My opening is 70mm, it has a ring on the inside.
Mark
Old 11-03-2004, 03:39 PM
steve911's Avatar
70MM are ring-type wheels
Mark--
A 70MM opening is a ring-type cap.
I have a set for sale here or hand painted ones here
RIP Warren
Old 11-03-2004, 06:48 PM
