-   -   Is there a benefit in just adding this? (http://forums.pelicanparts.com/porsche-911-technical-forum/190775-there-benefit-just-adding.html)
yama1 11-04-2004 06:06 PM
Is it worth changing stock cat to a fabspeed bypass to be used with stock muffler. Would it be better to wait for other changes.
(IE exhaust/exchangers)
I have 160k.
Doing some other maintenance and was thinking of this. All stock currently.
Just curious.
Mike Feinstein 11-04-2004 07:03 PM
Without improving the induction, you'll be wasting your money by only installing a cat bypass (Fabspeed or otherwise).
jtratza 11-04-2004 08:40 PM
It may be a waste of money but on mine the exhaust sound got deeper and that made it worth it alone. Actually I took mine off just to get rid of the heat on that side of the engine.
alf 11-04-2004 08:49 PM
Sounds better, weighs less, less heat next to engine, pretty easy to do if your bolts are not rusted in.
I felt an increase in performance when i made this change.
alf
Eric Coffey 11-04-2004 10:57 PM
Makes valve adjustments a lot easier too.
Por_sha911 11-05-2004 06:46 PM
Clogged cats cause other problems. Sounds cool. Runs cooler (temperature). Opens up the system for other upgrades like chips. Just make sure you won't need the $ if something breaks.
