Wheel bent!!!! what do i do?
ok so when i put new tires on the car they said one of my 7x16's is bent! it could still be ballanced out to 0
so how will this affect the cars handling? will it at all? can i get it bent back into shape? how much is it worth now? can anyone point me to cheap track wheels? i wont touch it if it cost muchos $$s i cant even afford good tires for it! heres a pic
SWB |
Call Al Reed. He'll be able to advise you on what to do about the bent wheel. He's often able to true them.
1984 Targa |
RETIRED
Hmmmm, bent and it balances? Sounds like horsecrap to me.....go see another wheel guy.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
One of the wheels on my wife's Corrado was also slightly bent and balances out okay. I balanced them myself on a new machine. As long as it's not too bad, it is possible.
George M '89 Carrera 3.2 '91 928GT '76 914 '18 Macan GTS |
There are a number of places that can straighten bent wheels - particularly alumium. Costs can go from $50 to $1000. Sometimes it takes a little heat to get them into tolerances. Do a search in your area - maybe call a few dealers to see who they use for this service.
Ken |
Make Bruins Great Again
Seems to me that heating a wheel to straighten a bend can't be good for the overall strength of the wheel.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
A qualified wheel repairer should be able to straighten your wheel. From what I understand the Fuche being made from a solid aluminium billet means that it is one of the few wheels that can be confidently straightened. From all reports Al Reed is the man.
2008 BMW 320i 2006 Mercedes ML320 2004 Mercedes ML270 cdi 1998 Porsche Boxter 1988 Porsche 930 Targa (sold) |
The problem with straightening a wheel is it should be absolutely true Zero, many people that striaghten them feel that 20-40 thousands OOR is ok, but actually its not on a Porsche, Mercedes, BMW, Audi etc, these cars are very prone to vibrations, some years ago even hre felt that 40 thosands was ok, its not, check on the BBS used board thats a pretty common wheel and you should be able to pick one up cheap, you can polish it or have someone else do it, Kevin
7x16's are cheap and readily available - replace it if it bothers you.
Randy '87 911 Targa '17 Macan GTS |
Rotorhead: Judging by your screen name and avatar, I'm guessing you're a fellow helo driver. True?
1984 Targa |
BTW, Fuchs are forged, not billet.
scottb: yep once a rotorhead... always a rotorhead. I had a couple of thousand Huey hours with a mix of helo types before I was seduced away to fixed wing. You actually have your own Bell 47! now that is cool. I haven't strapped into cockpit for 10 months since returning from Saudi Arabia. I am a (dis)respectfull businessman now!
What sort of flying have you been doing? Randy: Thanks for the correction
2008 BMW 320i 2006 Mercedes ML320 2004 Mercedes ML270 cdi 1998 Porsche Boxter 1988 Porsche 930 Targa (sold) Last edited by rotorhead; 11-05-2004 at 11:00 PM.. |
Although never using them, I have heard good things about this place http://www.wheelcollision.com/
I guess the heating is done only in the more extreme cases. Like if a wheel is damaged in an accident - it beats throwing it away! Don't kow If I'd want to use it for a race vehicle though. Most aluminum wheels that have been around a while are out of tolerance to some extent. If your wheel takes a lot of weights when balanced that would be a clue.
The Factory actually had rather poor tolerances for Fuchs runout and out of round, something like 1 or 2 mm.
My rim repair guy (any good repair person) straightens them better than new. A Fuchs, uness it is cracked in the center part, can be straightened. I have seen (and used) wheels that were like used Kleenexes before straightening. |
Senior Member
Rotorhead,
Your PM (personal mail) option is disabled. Can you please email me when you get time at: joeaksaATattglobal.net (remove the AT and replace with @) Was flying in Saudi as well... JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Rotorhead: What Joe said, except the Saudi part.
sib100 AT earthlink.net And, yes, I realize this picture is off-topic, but it does have an air-cooled flat six!
1984 Targa |
Fuchs w h o r e
There is no way to get any wheel to "absolutely true Zero". Every wheel you measure will have some runout. How accurate do you think the tread of your tire is? |
