-   -   am having difficulty shifting into 2nd and 4th gears in my 1983 911 SC help ! (http://forums.pelicanparts.com/porsche-911-technical-forum/191331-am-having-difficulty-shifting-into-2nd-4th-gears-my-1983-911-sc-help.html)
EliozarCuellar 11-08-2004 11:31 AM
:confused:
geof33 11-08-2004 11:33 AM
Do a search on SC 915 shifting issues. There is a TON of info on the site to guide you along...
Jim Sims 11-08-2004 11:39 AM
Probably loose shift coupler or one with worn bushings. Jim
EliozarCuellar 11-08-2004 11:39 AM
thanks. will go there right now.
GettinHeadStuds 11-08-2004 11:40 AM
Have you recently played with your shift coupler? If so, it may be out of adjustment. If you don't know what I'm talking about run a search on coupler adjustment; that should get you started.
Hey welcome to the board! 1983 SC... one of the best ever... ;)
EliozarCuellar 11-08-2004 11:42 AM
will inspect coupler and bushings. thanks
EliozarCuellar 11-08-2004 11:44 AM
glad to be on board . helps to get input from someone when in doubt
