3.2 Euro vs US
As I am reading Paul Frere's Porsche 911 Story, I see that the Euro spec 3.2 has stock HP of 233 while the US (catalyst) version has 207.
Is it a fair assumption that if I remove the catalyst (replace w premuffler) and get a chip to match euro spec (steve wong), I can easily achieve 233? Can I go further? I plan on keeping muffler and heat exchanger. Want the most HP for the least dollars. Chris
Chris 1985 Carrera http://www.pelicanparts.com/gallery/ckmaggie |
euro has roughly one more point of compression (10.3) - 231 horsepower
To answer the orig question, I think the chip helps. It really helps to have the chip built to your needs and based on your car's specs as well as the fuel you use.
Mark O. 1997 993 Twin Turbo S 1985 911 V3/R5 POC Track Car 2001 740i - Daily Driver 2004 F150 - Toy Puller Sold: 97 993 Carrera S 95 993 Cab |
Doesn't want/need a 3.6L
My original 3.2L with a Steve Wong chip, Dansk pre-muffler and Dansk stainless muffler made 199 rwhp (some have seen more) which puts you in the horsepower neighborhood your contemplating. All with, ahem "9.5:1" US spec compression. Ralph |
Sorry I wasn't clear Creaturecat. I didn't mean to bunk your comment. I just meant that the reported and actual differ greatly (as the person above put it [a bit better])
not a problem!! Mark in Hermosa
