-   -   Clutch Stop part (http://forums.pelicanparts.com/porsche-911-technical-forum/191478-clutch-stop-part.html)
Porsche-poor 11-09-2004 07:54 AM
Clutch Stop part
Anyone have a part number or know if this can be fixed. I know I'm missing the rubber piece. Got to digging in the floor board last night and it looks like the former owner left it this way for some time. The floor board is even cracked on the left side where they tried to push it through the floor.
Thankshttp://forums.pelicanparts.com/uploa...1100015658.jpg
Randy Webb 11-09-2004 11:47 AM
mine is missing too, so I am gonna bump this up.
if we can't find this item, we'll have to look for a piece of real thick rubber and then cut it to fit
Jim Sims 11-09-2004 11:57 AM
I've ordered and received these; both the bracket and the replaceable rubber stop. I'll look up and post the part numbers tonight if someone else doesn't do it first. Jim
Randy Webb 11-09-2004 11:59 AM
Thx Jim!
BTW, in another post you mentioned your car was in No. Cal. What's up? Is it getting some special treatment that can't be done in NM? IF so, can you tell us what it is, and how exotic it is?
Jim Sims 11-09-2004 12:05 PM
It's getting a mechanical engineering degree with my son at UC-Davis; he mostly restored the car. Jim
Porsche-poor 11-09-2004 12:18 PM
Great, I look forward to those numbers!!!!
Randy Webb 11-09-2004 12:38 PM
Good to hear. I'm assuming its the '74 you mentioned you'd reconstructed. Of course, at UCD he will have to run it on PV panels, or bio-fuels....
Jim Sims 11-09-2004 05:07 PM
Stop (metal bracket): 901.423.360.00
Rubber profile (bumper) that fits in stop: 901.423.392.00
In the interest of completeness here are the fasteners that attach the stop to the floor board:
Support (threaded round nut plate - 2 required): 901.423.368.00
Toothed lock washer (A5.3 DIN6797 phr - 2 required): 900.114.009.01
Cheese head screw (allen head screw, M5 x 15 DIN 6912- 8.8 verz. - 2 required) 900.119.025.02
Cheers, Jim
Randy Webb 11-09-2004 05:48 PM
Thanks!
I am REALLY glad I still have the metal piece - its over $45 at Pelican....
the rubber stop .... Part Superceded to 90142339100
Jim Sims 11-09-2004 06:29 PM
Yep, if one has the stop it may be worthwhile carefully reshaping it to hold the rubber bumper; it appears the bumper slips out and then that section of the stop becomes mashed by the pedal arm.
Brad (21 today) and his 1973.5T in California.
http://forums.pelicanparts.com/uploa...1100053719.jpg
Jim
Porsche-poor 11-10-2004 07:51 AM
Thanks for the part number. I think I will try and reshape it and add the rubber piece.
Dave
1982911SCTarga 09-13-2005 08:30 AM
This is an old thread, but I just finished rebuilding my '82 SC driver's floorboard, which was cracked at the clutch pedal opening, broken at both tabs at the top and delaminated in many places. It was also missing the rubber clutch stop. In effect, the floorboard was holding up the carpet and doing little else in terms of performance.
I used laminating epoxy to re-glue the plywood floorboard in its weak spots, and to mount two new plywood tabs to the top section so it would mount correctly. To further reinforce the floorboard, I fiberglassed both sides with 4 or 5 oz. cloth (the type you get at the auto parts store) and laminating epoxy. This takes time, but the end result is a very strong floorboard.
For the missing rubber clutch pedal stop part, I cut a piece from a rubber plug from Home Depot (cost: $2.50) using a fine-bladed coping saw. This piece is just slightly wider than the metal bracket. Using a screwdriver, the new rubber stop presses into the travel-adjustment bracket. Some work with a Dremel sanding drum finished the shaping of the rubber stop.
The end result: My clutch travel is dead-on and my floorboard is good to go for many, many miles.
It's fun being cheap.
