-   -   Question on installing shift shaft seals? (http://forums.pelicanparts.com/porsche-911-technical-forum/191575-question-installing-shift-shaft-seals.html)
RickKlem 11-09-2004 05:26 PM
I'm ready to install a new shift shaft seal and the output shaft seals (cv flange) .Do I install them dry? Or should I use a lube or a sealant of some type?
Rick
jeff1hughes 11-09-2004 06:30 PM
i am sure on the shift shaft seal that you should use a light coat of non-hardening rtv sealant (black silicone is good) on the outer edge of the seal when installing it. I would assume that the CV seals are the same.
AFJuvat 11-09-2004 08:07 PM
light coating of oil on the sealing lip - thats all
AFJuvat
Randy Webb 11-09-2004 08:54 PM
I used oil also. Be sure to clean the sealing surface and ensure it is smooth.
Tap the seals in carefully and don't let them get tilted.
jeff1hughes 11-10-2004 05:00 PM
just to clarify, when I said outer edge I meant the metal part that contacts the trans housing.
