Randy Webb's Avatar
changing oil pressure strip gauge inside dial
I am wondering if the oil pressure strip gauge from a 84-89 911 Carerra can be removed from the dial instrument housing and installed in the '73 dial gauge in place of the one that is stock in a '73?
I know the 356 people do this to their gauges. Can you do it in a 911?
Reason: The sender on my '86 engien will not run the stock '73 gauge. (And the screw-in orifices are different sizes. The great adapter fix that Jim Sims posted about in 2001 won't work here, as the sender I need to use is larger than the mounting point.)
So, unless somebody has a better idea, I plan to change the gauge itself to work with the new sender.
Old 11-09-2004, 10:42 AM
Early_S_Man's Avatar
Porsche Crest
Randy
The Carrera or SC gauge internal 'half' will fit perfectly in a '73 gauge housing. Other option below ...
Your car's engine has an oil pressure switch up on top of the engine near the engine oil thermostat ... I believe the early pressure sender will fit perfectly in place of the pressure switch.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-09-2004, 08:04 PM
Randy Webb's Avatar
Thanks Warren. You're right the early sender fits perfectly there -- one is there now. The problem is that position is apparently used for the oil temperature sender which now no longer works.
Old 11-09-2004, 09:08 PM
