-   -   911 CAT question(s) (http://forums.pelicanparts.com/porsche-911-technical-forum/191682-911-cat-question-s.html)
audi2.7t 11-10-2004 10:40 AM
911 CAT question(s)
So ,I finally started getting the motor out in preparation of the full re-paint. I identified the turbo as a Turbonetics T04 .96 which will be going for a re-build and got a chance to check out the rest of the exhaust. It seems to be an original CAT but it's straight through ? ie. it seems to have a solid 2" or so pipe welded in ,when you look in towards the collector there's no baffles, holes or anything is this normal ? also, there's no O2 sensor in it ?.I've tried calling Protosport with questions but they were very vague about everything and suggested I bring it to them to check everything out (understandable), any thoughts ?
thanks,
Sam.
Wil Ferch 11-10-2004 01:22 PM
Any original cat would have an O2 sensor bung.....
You might have a Euro-spec pre muffler but this has a perforated plate co-axial inside...otherwise straight through. Would have a 930 XXX or 911 XXX part number stamped somewhere on the body if it's a pre-muff.
Pics?
Wil
Groesbeck Hurricane 11-10-2004 02:22 PM
Post a photo, but you might have a CAT that has been hollowed out and the bung replaced or a piece manufactured to resemble a CAT.
audi2.7t 11-10-2004 04:19 PM
part # 930 113 230 08 1X83
is this a Euro ?http://forums.pelicanparts.com/uploa...1100132338.jpg
http://forums.pelicanparts.com/uploa...1100132378.jpg
audi2.7t 11-10-2004 04:21 PM
Notice it has the bracket for the wastegate.....
and here's the turbo
http://forums.pelicanparts.com/uploa...1100132484.jpg
Wil Ferch 11-11-2004 06:28 AM
The first picture along its length you can see the "test port nipple" to attach the instrument that checks the effectiveness of the catalyst action ( what is this called?...CO wand?).
With that...I'd say it's a hollowed out cat. How 'bout someone running a PET against the number?
Wil
