efhughes3's Avatar
Pulley and flywheel seal questions
One of my "while you're in there" tasks was to replace the pulley seal. Now, as I've spent some time with the motor, I've got no leak in this vicinity. Should I leave well enough alone? Or, use the opportunity to replace?
BTW, I did replace the seal behind the flywheel, when I put it back in, it ended up recessed past the case surface by 1/8" Is this a problem? All data I see say to go flush, but I got one point a little deep, and then pushed the rest of the seal in to match.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 04-09-2005, 05:06 PM
randywebb's Avatar
I usually sink these things so they are not where a rubbed depression might be....
Did you feel where the old one was?
If not, you are prob. OK.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-09-2005, 07:20 PM
efhughes3's Avatar
The crank didn't seem to have any wear marks, if that's what you mean? I guess I roll the dice....
Any opinion on the pulley seal? Let it ride?
Ed Hughes
2015 981 Cayman GTS
Old 04-09-2005, 07:33 PM
randywebb's Avatar
No, the inside - not the crank itself - at least that's what I did.
Yeh - roll
Old 04-09-2005, 07:42 PM
DavidI's Avatar
I would leave the pulley seal alone if it is not leaking. If it does start to leak in the future, it is not that big of a job to install a new one.
99 996 C4
11 Panamera 4S
83 SC Targa converted to a 964 cab (sold)
67 912 (sold)
58 Karmann Ghia choptop (traded for the 912)
Old 04-09-2005, 08:18 PM
efhughes3's Avatar
Thanks David. That's what I was thinking.
Ed Hughes
2015 981 Cayman GTS
Old 04-09-2005, 08:53 PM
