-   -   What am I doing Wrong? Help (http://forums.pelicanparts.com/porsche-911-technical-forum/191730-what-am-i-doing-wrong-help.html)
deoxford 11-10-2004 05:28 PM
Ok I have a 72T with 2.4MFI I can't get the started to turn over.
I might have not connect something correctly but I am not sure.
I am putting the car back together and very well cound have missed something.
Ok here it is
When I turn the key the controls in the engine bay whine , and the fuel pump comes on.
But the Starter will not kick in , where do I start?
Also I think I need a new headlight switch when I turn it on the right side runing lights come on , and the left head lights . what do ya'll think?
Thanks for the help
Derek
Here is the project.
http://www.356-911.com/911restogallery/derekoxford911.htm
Jim,
What do you think?
afterburn 549 11-10-2004 05:32 PM
can you jump the silly thing on top of the starter??if that works you have a bad one.....But 1st always start with a charged batt. with clean conections (no guess work here)
Fishcop 11-10-2004 05:32 PM
Can't help you with the starter, but the left and right lights are on separate fused circuts. I'd say you're experiencing resistance on the left side, probably as a result of a dirty/corroded fuse contact.
Randy Webb 11-10-2004 05:52 PM
define kick in?
does it click at all? do the lights dim when the starter position on the ign. switch id engaged?
deoxford 11-10-2004 06:13 PM
Randy,
does it click at all?=No
do the lights dim when the starter position on the ign. switch id engaged?=No
I do have a brand new battery and new connections
Randy Webb 11-10-2004 07:58 PM
Measure the batt. voltage just to be sure it is 13.8 V or so.
If so, you have a bad solenoid - assuming that power is getting to it. You can measure voltage to gnd at the wire from the ign. switch to the starter. You'll have to crawl up under there - it's a lot easier on a lift, and a lot harder on cold wet mud....
Do a search and that will help you get oriented before going underneath.
deoxford 11-10-2004 09:15 PM
Do you read the voltage at the yellow wire?
on the starter? how do you check if the Solenoid is bad?
I just what ot make sure that I have every thing hooked up ok.
I don't want to think the solenoid is bad, if I did something wrong.
Is there any way to check to see if I gettting what I need to there?
The starter worked fine when I pulled the engine.
Derek
deoxford 11-11-2004 02:46 PM
Can you test across the coil /solenoid to see if it is open?
deoxford 11-11-2004 02:47 PM
Also can you just tap them like American starters?
