Friend of Warren
3.2 Footwell Blower + Heater Backdate = Failure!!!
For those who have been following my tech article Tech Article on getting the footwell blowers to work without the engine blower, I have an update. Apparently the ballast resistor can't handle constant use. The ceramic resistor becomes brittle and vibration from driving eventually breaks it apart. Oh well, I guess I will next try the rewiring of the automatic heat console.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Great. Just when I think I'm ready. Sorry to hear it didn't work. It sure sounded good. Thanks for the update.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
Just saw your post on the ballast resitor... mine hasn't blown yet.
this guy houses it in a box and it looks to be isolated from vibration... http://www.porsche964.co.uk/technical/noheater.htm there's also other resistor options that are much more rugged. how about this bad boy... http://www.action-electronics.com/resist50.htm
Database and Website Consulting Services in Chicago |
It's like driving around with a toaster in your engine bay.
j.p. |
Document rewiring the auto heater control
All the backdaters (and auto-heat control haters) could use the detail on that!
Thanks, Chris |
Okay, well, I got my footwell blowers to work without the engine blower on my 3.2.
In fact, the switch on my car for the headlight washers is now the "full-on-gimme-heat-til-I-die" switch now. Kicks them in, and they work great. I just disconnected the two wires for the washers and and hooked up a couple of extensions that run from between the seats under the carpet and behind everything up to that switch below the speedo.
-kb- |
Senior Member
Kurt,
Sorry to see it give up the ghost! Keep us filled in on the next move! JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Hey Kurt - some of the better quality resistors have the element embeded in epoxy, so they're a lot more durable. I think you just had a cheap resistor. One of the links above might lead to somthing like that, haven't had time to look.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
Any chance the updated 993 a/c fan and oil cooler ballast resistors would work? They look a lot more robust and are coated in epoxy. I don't have a photo of one, but there should be some on www.p-car.com. They are known weak spots in 993's and I think they've been improved upon.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Friend of Warren
Thanks for the pointers. I will order one of the aluminum house resistors and see what happens! Updates and pictures to come.
Just ordered one of these (50watt, 50 ohm resistor): ![]()
Kurt V No more Porsches, but a revolving number of motorcycles. Last edited by Rot 911; 11-11-2004 at 05:12 AM.. |
Kurt... keep us posted. I'm going to order one of those things anyway. I'd also like to find a better location for it.
Note the bottom pic in this thread... can you see the ballast resistor sitting back there? ![]() My $25 heater backdate for 3.2 w/pics
Friend of Warren
Couldn't you just hook up a relay to the fan wire to make the footwell blowers run. I don't think using all that electricity to complete the circuit will help the battery and charging system. There has to be a better way.
87 Carerra Coupe 04 GMC Yukon 07 Mazda 3 00 GMC Sierra |
