-   -   Deep 6s and flat 6 fuchs - difference (pic) (http://forums.pelicanparts.com/porsche-911-technical-forum/191817-deep-6s-flat-6-fuchs-difference-pic.html)
Alan.UK 11-11-2004 08:13 AM
Hi all,
I just quickly put this image together for a friend and thought I would also post it here, just incase it helps.
Alan.UK
http://forums.pelicanparts.com/uploa...1100189598.jpg
speeder 11-11-2004 08:30 AM
Thank you for that, good post! :cool:
RarlyL8 11-11-2004 09:58 AM
Thanks for the post.
I had a set of "deep" wheels on my '73T. Never knew what the difference was.
Early_S_Man 11-11-2004 10:19 AM
Alan,
Rear, inside closeup pics would be helpful, too, as I suspect very few people are aware of the reinforcement ribs on the early, tube-type wheels ... that radiate out from the root of the spokes outwards towards the inner (back) side.
trj911 11-11-2004 10:22 AM
Very interesting. I've been curious about the difference and now I know.
Alan.UK 11-11-2004 10:59 AM
Hi all,
No problem Warren. Here is a pic of a pair of deep 6s plus a picture of the inside of the rims. The fully polished deep 6, clearly shows why these rims get their name. Also the last picture shows the raised lip around the valve hole, flat 6s do not have this feature.
Alan.UK
http://forums.pelicanparts.com/uploa...1100199457.jpg
http://forums.pelicanparts.com/uploa...1100199488.jpg
http://forums.pelicanparts.com/uploa...1100199508.jpg
Randy Webb 11-11-2004 11:12 AM
Great info.
One query tho - do all flat sixes have a safety bead, or just the later ones? See the 1st pic for the ambiguity.
gregk1 11-11-2004 11:21 AM
I have some deep 6's with no safty bead is it a must to run tubes with these?? I just run around on the street, no track or autocross just normal every day driving
Alan.UK 11-11-2004 11:37 AM
Hi Randy,
Sorry for the confusion, all flat style 6s have a safty bead. Its the earlier (1969-some time within 1971) deep 6s which do not have this beading.
The flat 6 in the first picture does have the beading, but it is not very clear.
Scott Clarke 11-11-2004 12:41 PM
Greg-
The safety beads have no relationship to the use of tubes. The safety beads prevent the tire from leaving the bead in the event of a rapid deflation. this could occur with or without tubes. Deep 6s are fine without tubes.
-Scott
dvkk 11-11-2004 02:37 PM
Scott is right about the safety bead humps and tubless tires. VW went to tubless tires in 1957, but didn't incorporate safety bead humps until 10 years later. Porsche was obviously a little slow, and just happened to upgrade both at the same time.
Shaun @ Tru6 11-11-2004 02:46 PM
great post.
Question: how does a deep 6 differ from a 911R wheel?
Alan.UK 11-11-2004 03:47 PM
I have more comparison pics between a deep 6 and 7R rim that I can post tomorrow when I am back in the office...
Alan.UK
Anders-M.I.B 11-14-2004 09:28 AM
Deep or flat fuchs
Hi
Here is an other good picture!
http://home.no.net/jhu/Felger%20page/Newold%20fuchs.jpg
Hi Alan-UK
How are you ;) ???
Anders
RarlyL8 11-14-2004 09:34 AM
That picture tells the tale.
Which type wheel is more valuable in terms of resale?
dvkk 11-14-2004 10:51 AM
Shaun,
The difference is only in the inner lip. From the mounting face out they are identical. All they did was stretch the inner rim.
I'll try to post a pic:
http://www.thesamba.com/vw/gallery/pix/84078.jpg
On the left is an early deep 6 sitting on 1" wood block.
Early deep 6s are worth more than late 6s in comparable condition.
Shaun @ Tru6 11-14-2004 11:03 AM
Thanks, that's exactly what I wanted to know. Someday...
randywebb 11-14-2004 11:17 AM
It seems the deep Fuchs are more valuable even tho they are _less_ safe, and harder to clean....
Alan.UK 11-15-2004 11:42 AM
Here is a couple of pics of the 7R rim compared to its thinner 15 inch brothers....
4.5 then 5.5 then deep 6, then flat 6 and finally 7R
Alan.UK
http://forums.pelicanparts.com/uploa...1100547668.jpg
http://forums.pelicanparts.com/uploa...1100547683.jpg
PS. Anders, I am well, how are you???SmileWavy
Anders-M.I.B 11-15-2004 01:05 PM
Hi
Remember if you want to mix the front and rear size.....
Then use the early fuchs....the late(flat 6) don't match up with the early fuchs style.
The Fuchs "Star" are not the same size "early deep vs. late flat"
I will run my early 4.5's front and 5.5's or early 6's back when I find some for the back ......sold my late/flat 6's because the don't match up with my 4.5's
Alan.....Just married 2 month ago ;) so all good
ty901 11-15-2004 01:09 PM
Alan;
let me echo the 'thanks for a great post' comment. i will add one thing about the "bump" section around the valve stem area. this seems to have been "flattened out" sometime in '71. ie; no variation in the overall opening between the 2 spokes where the valve stem lives. i can post a pic, but will take a couple of days. someone else maybe have one handy. i think there were some of these on the 'for sale' page. on a different topic, i hear some say that there is a problem finding valve stems for these wheels due to the excessive depth of the forging at that point. comments ?
thanks again
cheers
jerry
Alan.UK 11-15-2004 01:30 PM
Congratuataions Anders !!!
Also thanks for the extra info Jerry, from memory I think the valve bump stopped when the rim changed from deep to flat style. Just noticed your in S.F Bay Jerry, wish I was, its cold and wet here on the South Coast of England....
Alan
ty901 11-15-2004 01:51 PM
hi Alan;
well... the weather is definitely changing here. we've already had a couple of good storms. i may be heading your way for a vacation next year. for pix of "late" deep 6's try this;
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/172366-deep-6-fuchs.html
right part number, but no bump. i have 1 or 2 of these myself.
just one more thing to watch out for!
cheers
jerry
azasadny 11-15-2004 03:54 PM
Alan,
Thanks for the info and very clear pictures, that really helps me understand the differences!
Alan.UK 11-16-2004 12:56 AM
Thanks for the link Jerry, if you're coming over the UK make sure you let me know, you can borrow what ever early 911 I have to blast around the country roads. You must visit the south coast, it's great round here.
Alan
ty901 11-16-2004 09:42 AM
Alan;
...or should i say "my newest best friend" ;-) many thanks for the kind offer! i'll be sure to keep you posted and please do let me reciprocate if you find yourself in my neck of the woods.
cheers
jerry
Britain Smith 11-17-2004 10:43 AM
So this thread got me thinking about the possibilities of having deep fuchs on my '69 912. I went out today and looked at the rims, they have the 901.361.012.04 part number but are 5.5Jx15's. Are these considered "deep" fuchs? They have several of the features that were described in this thread.
-Britain
Anders-M.I.B 11-17-2004 11:31 AM
Hi Britan
Yours 5.5's are early fuchs and also good to have
here are some parts number:
Early fuchs 901.xxx....
901.361.012.01 4.5x15 42mm offset - 100mm backsize
901.361.012.04 5.5x15 42mm offset - 112mm backsize
901.361.012.06 6x15 36mm offset - 112mm backsize *deep dish *
901.361.012.05 7x15 49mm offset - 138mm backsize *911R*
Late fuchs 911.xxx....
911.361.020.10 6x15 late/flat
hope it helps
Alan.UK thanks alot mate SmileWavy
I'm looking for more fuchs you know ;)
ty901 11-17-2004 11:55 AM
hi Britain;
your 5.5's supposedly were only offered in '68, check your date stamps, but don't be worried if you don't find any. this was not consistent in the early days.
Anders;
thanks for more good information. as a note, the '72-'73 (approximately) version of the "flat" 6 is;
911.361.020.00 and takes the 3-prong cap, while the .10 wheel takes the ring-type.
best
jerry
Alan.UK 11-17-2004 12:58 PM
I have just picked up a set of deep 6s and they are the later ones you were talking about Jerry, ie. Deep 6 style but without the raised lip around the valve.
I also had a guy contact me today who wants 12 4.5x15 for his ralley cars, wow.. who's got 12 4.5 fuchs?
Take it easy guys
Alan
Britain Smith 11-17-2004 01:39 PM
Originally posted by ty901
hi Britain;
Anders;
best
jerry
Are you talking about the date stamp on the rims themselves? I will check this evening.
-Britain
ty901 11-17-2004 09:18 PM
i just checked a "non-bump" 6" deep. it's dated 10 70.
914timo 11-17-2004 11:57 PM
You have very nice collection of old Fuchs wheels, Alan. I love them too. I have never had 5.5X15 Fuchs, but I still have one pair of 4.5s and 6s for my ´51 Beetle. Couple of years ago I had 7 911R 7x15 rims. Then I sold a pair for my friend here, one full set to England and the last one to California somewhere. I still miss them sometimes. They were great under my 914 with 205/50 tires. The only problem with them was the transmission rations. They were too close with six. Thats why I chanced them to 16 inch wheels. They work better, but dont look as good :)
Jason Cullen 11-18-2004 12:08 AM
Alan,
Excellent Presentation - A big round of applause! One of the best posts!
Great Job.
Jason
