how to print complete wiring diagram?
pardon my compooter illiteracy, but how do i print out the wiring diagram completely from the tech page? i only get one quarter of the diagram and can't seem to find the other "pages"
thanks |
save the doc as .jepg then open a photo edit program and customize to a A4, legal size then just print it
Depending on your printer and driver you may also be able to right click on the image and select Print Document. Then adjust paper size or use "fit to page" option.
IE automatically resizes the diagram to fit on your screen so it can be confusing. |
ok- will try that
thanks |
TRE Cup,
At 8 1/2 x 14, the drawings are pretty hard to read. IF you have access to a 11 x 17 printer, use that, set your print options to "fit to page" and you will have a nice usable diagram. |
I use Paint Shop Pro, and tell it to use the full page size/fit to print and center on page. I use this method to print VW wiring diagrams on E sheets here @ work.
Where are the diagrams? I could print them out nice here and mail it to you. |
TRE, just go out and buy a $10,000 color plotter....no biggie. JK |
Thanks Thom- that would be great- that way i can read them w/o the coke bottle thickness glasses
Which diagram do you want?
I kicked off printing the 1965 911S diagram before I left the office last night; props to whoever scanned it - great job!
It will take me a day or so to discreetly print these. We used to have a nice glossy paper, but I wasn't able to find any, so they're on light-weight E sheet. I'm printing a set for Tyson, but I will not be able to fulfill everyone else's printing needs - sorry :( |
I print out wiring diagrams and then go to Kinkos and have them enlarged and covered in acetate.
Here are some cleaned up, high and low resolution pdf's of electrical diagrams L57, L59, SL33 and SL35... they have been formatted to fit 11x17, but are of a high enough resolution to print much larger... I wouldn't mind printing a few big ones if the demand doesn't get out of hand... say 5-8
http://www.scatliff.mb.ca/pelican/Electrical_Schematic_L57(high).pdf http://www.scatliff.mb.ca/pelican/Electrical_Schematic_L57(low).pdf http://www.scatliff.mb.ca/pelican/Electrical_Schematic_L59(high).pdf http://www.scatliff.mb.ca/pelican/Electrical_Schematic_L59(low).pdf http://www.scatliff.mb.ca/pelican/Electrical_Schematic_SL33(high).pdf http://www.scatliff.mb.ca/pelican/Electrical_Schematic_SL33(low).pdf http://www.scatliff.mb.ca/pelican/Electrical_Schematic_SL35(high).pdf http://www.scatliff.mb.ca/pelican/Electrical_Schematic_SL35(low).pdf |
| All times are GMT -8. The time now is 06:08 AM. |
