Ok, that stupid little "U" shaped wire clip, which secures the engine wiring harness plug to my ICV, has gone missing!! Does anybody have a source for those things? Pelican doesn't list it as a seperate item. I could safety wire it on it but I'd rather use the real deal if possible.
Thanks.
John |
You can check at a wrecking yard. They are common on many European cars. Don't run too long without it. These style connectors need to be tight in order to seal out moisture. We chased an intermittent no start problem on my son's 951 for weeks, before finding that it was a reference sensor connector that was missing the wire clip. Someone had used a zip tie to hold it on. The moisture inside the connector oxidized the terminals.
'69 911 Targa w/ 3.2 |
Thanks Midlife, I'll check out Parts Obsolete first. Shipping will probably cost more than the part! ;-)
John |
