another round please
optima yellow top problems, cause?
My 86 911 has a Optima yellow top battery. When the car sits for lets say a week, it drains out of juice. Ive brought it to Autozone and had it re-charged. The date code says is was sold March 04, and the build date was Sept. 03. It says that they will replace for free up to 12 months. The company, after a few long talks, said that is only for the original owner???? But they said they would replace it, after asking for the supervisor, if it failed a load test. It passed fine, so I guess no replacement. BUT, when I try to hook up a trickle charger to it, (shuemaker brand) after about 5 minutes, it goes to red light, problem, and wont keep charging. What do you folks think is the problem, with not being able to charge it up at home?
Getting old is not for wimps. |
it's a deep cycle battery. Deep cycle batteries need an alternator designed for it.. long story.
give it to the local boat yard.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Thanks. Ive heard that yellow tops are for boats. Do you think I should change it asap.
Change to the Red Top when it's doable.. the battery is still probably in very good condition.. for a boat, golf cart, wheel chair, etc Disconnect battery from car when charging.. always Don't jump from another car. Don't jump another car.
Thanks. Do I take off both the positive and negative cables from the battery when I use a trickel charger. When I tried it today, I left the negative cable on, and after about 10 minutes, it came up with a red light problem. Is this why I got a "red light"? Thanks for any reply
I would guess that your best shot is to get a Red Top tomorrow and let the deep cycle be the prob of the next guy you give it to. Or buy a 50-100$ charger. trickel charging.. I always disconnect the neg cable with the wing nut on the battery marine clamp.. costs about $5 + new ground cable. So anyway the trickel puts out very low current and your system may draw 60ma to start with. + a trickel will never redo a deep cycle, imo.
I had the same problem with mine awhile back and it was the battery. Charge it, disconnect it from the vehicle, let it set for a week and try it. If it doesn't start the car then you know the answer.
I purchased mine from Batteries plus and they gave me a 3 yr replacement with a 2 year pro rated on top of that for a total of 5 years. Steve "A Porsche does more then just go fast in a straight line"
SteveKJR Proud Owner of a 78 911 SC Targa "A Porsche does more then just go fast in a straight line" |
NEVER remove a hot ( positive) lead first and leave the negative installed!!!
You BET I'm shouting !!!! (Always remove the neg cable first....then the positive if you have to remove both.) When you re-install...install the positive first and negative last. BASIC electrical battery cautions.....not Porsche-specific..... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
It has to do with the current that may remain in caps, etc. Car fire battery disconnect is the same routine. I simplify the easily forgotten words with "negative thinking"
I did some research on these batteries for my battery relocation project. All of the above is correct from what I have read. The yellow top is a nice compact size and was aimed primarliy at the small import market. It is however a deep cycle battery - and could be used for marine applications ie trolling motors. You want to almost fully discharge the battery and then charge it up all at once to keep these type operating at peak efficiency.
Large stereos, video, video games coffee makers, espresso machines etc. You name it they stuff them into the cars...sit parked and use them up. Then they charge them back up again. These are not batteries for a 911 that seldom gets used... -Jeff nolift911@hotmail.com Last edited by NoLift911; 11-15-2004 at 12:56 PM.. |
Thanks guys for all your help. When I store my car, say for a week, I have been taking off the positive cable. But it sounds like this is a NO_NO. The yellow top seems to drain so fast, that I dont know how long it will last. I did replace it with a duralast battery yesterday. It came with the car when I bought it, so I didnt know about them. So, if I want to trickle charge it, take off the negative first, and then the positive, then hook it up to the charger, is that correct. Thanks
I remove the negative only for charging.
Sports Purpose 911 Driver
btw
The reason that Tyson had trouble with Scrappy on the way out west was because my dumbass was running a yellow top optima. It worked for about 6 months but finally ruined the alternator. Listen to Ronnie, ditch it. James
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
You got it, it's ditched.
Two clarifications..
1.) yes..take the negative lead off first. Here's a help to remember..if the negative is "off"...and it accidentally drops and hits the metal chassis...what happens? Nothing! Thr "ground" wire has "grounded". Now...if you had removed the hot positive wire ( being the first wire you disconnect) ..and it hits the car...sparks and welding ! ( or worse) Capice ?? 2.) Trickle chargers...like the "computer chipped" ones....can be attached to the positive and negative leads of the battery IN ADDITION to the normal negative and positive leads remaining attached. Just remember to detach the charger ( or at least unplug it from the wall) when you start the car .... Wil
Great advice...Wil & Ron both. I use a 2 amp auto shut off charger from time to time. It works fine with both batteries hooked up. Deep cycle not desirable for cars, which are designed to use a bit of juice under starting load, then replace it as the car runs. Red top optima is a good battery...
Ronin STOP!!!!!!!!! These batteries should never be charged at anything higher than 10 amps!! There is a good chance that the punks at AZ didn't know any better and fried the battery for strup. These spiral cell batteries are very picky at how they're charged up. They work very well and should not be draining after a week at all, deep cycle or starting battery. I'd take this battery back, get a new one (prefferably a starting battery) and let the cars alternator charge it, you don't need a special alternator to charge a battery.
86 Carrera Targa - Garnet Red Metallic 88 928 S4 - Gran Prix White |
Jeff.. deep cycle needs a voltage regulator different than what we have in all autos. Do I have to search and scan hard info? Do your own searching and then let us know. I'll bale you out if you can't find it, no problem.
Keith, I believe you are mistaken. That type of battery doesn't like input much greater than 14 amps, and "less is better". At least, that's the way I understand things. Any battery dealers out there?
