915 Transmission Tools, Vancouver BC
Looking to borrow or rent at a cost any synchro hub removal tools for gears 1 - 5 on my '77, 915 Transmission. Or a shop that has the tools and will remove the syncro hubs for me. I am located in the Vancouver, BC area. I am replacing the entire 1st gear and following through with the syncros on all the other gears. Thanks.
Old 11-15-2004, 01:06 AM
indigowhale's Avatar
Send a message via Yahoo to indigowhale
I am in the prospect to do the same. If you find some tools, let me know. I think John Walker said, don't quote me it was late, to take a few rags lay them on a concrete floor and take the end of the shaft and smack it down on them. The inertia will drive the gears off. Don't take my word for it, read it for yourself:
Can't Shift Into First
Best of luck.
Indigowhale
1990 Carrera 4, 1984 Carrera, 1986 Carrera -
1987 944, 1979 SC, 1969 911T, 1971 914 -
Old 11-15-2004, 10:04 AM
that's for disassembling the shafts, not the syncro teeth. i've done it with a hammer and sharp knife-edged chisel in a pinch. in fact, turbo 2nd gear needs to be done that way because nobody makes a puller for it. or you can bring them or send them here.
206 637 4071
Old 11-15-2004, 10:08 AM
Fuchs w h o r e
Check in at Bert's Automotive on Kingsway in Vancouver. There used to be a guy named George there (retired now) that was extremely knowledgeable in Porsche gearboxes. Maybe they have someone else there that knows their stuff. They may also still have the tools.
Old 11-15-2004, 02:44 PM
I appreciate all the response I received as well as the hyper link. This will definately come in useful.
If John Walkers Shop would like to quote me a price on removal of all the syncros and re-installation of all the gears I would appreciate it. I will drop the engine separate the transmission and do as much possible. Two Quotes.... if I supply the parts or your shop supplies. Thanks very much.
email is dshap@telus.net
Old 11-17-2004, 11:34 PM
Slumlord
Porsche_monkey's Avatar
UPS them to John W. You won't be sorry you did.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 11-18-2004, 05:47 AM
it only takes about 5-10 minutes each to swap the toothed ring. i don't want to qoute parts prices on this website, pelican being a parts seller.
206 637 4071
Old 11-18-2004, 08:00 AM
j. brian mulloy's Avatar
This attempt No. 2 to send this reply
There is another guy in North Van who runs a Porsche shop, 'Frank Allers Autosport'. I've only met him twice and for very brief moments. He is very knowledgeable, a likable, laid-back kind of guy and quite approachable. I believe he submits road test articles for 'Western Driver' and has a local reputation as quite a driver. A guy named George Allen used to be his partner but I've heard he works for 'Wetmore Motors', also in North Van. I hope this helps
Cheers
Brian
Mens Agitat Molem
1970 T (presently in pieces)
Old 11-19-2004, 01:14 PM
Go Speedracer, go!
SpeedracerIndy's Avatar
If you have a chisel and hammer you can do it yourself! It takes less than 10 minutes to separate the syncro hub from each gear. You just tap with the chisel between the gear and the syncro hub around the gear until it begins to slide off. When you see a gap, you can slide a screw driver on each side of the syncro hub and pry the hub off with the screw drivers. To put the new hub on you can just press it on with a vice, or have a local shop press them on. I heated mine up with a propane torch before I pressed them on to make it a little easier. If you don't have a chisel and hammer, it will cost less to buy them than it would to ship them somewhere and have the work done. Just my opinion of course.
1981 SC ROW Coupe
Old 11-19-2004, 01:38 PM
