Coralbut's Avatar
Question Early 911 Door stop question
I have a 1972 911T and the doors make a loud snapping noise when they are opened beyond a detent in the door stop mechanism. When I watch this happen, I see the clevis pin that holds the door stop jump. The snap noise seems to be getting louder. What should I do to fix the problem? Do I need a new door stop clevis pin so there is no play? Do I just need to lube the mechanism? Thanks.
'72 911T 2.7L
Old 11-20-2004, 09:35 AM
Wandered off somewhere...
Drdogface's Avatar
Check Pelican catalog for Door Stay Re-enforcement kit. Sounds like what you need before you ruin the door sheet metal. Get the "101 Projects...." book for better detail on how/why to do this and other projects.
Mark...
Porsche Boxster S
2012 Jeep Wrangler Rubicon..Crush Orange
Old 11-20-2004, 09:38 AM
HarryD's Avatar
Before you go to that expense, check this thread: Driver door "CLICKS" when open/closes
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-20-2004, 02:11 PM
Coralbut's Avatar
Thumbs up
Thanks for the tips you guys. I will try the cheap route first because there doesn't appear to be any damage. If the sheet metal is totally torn and ripped, I'll have to put in the door stay reinforcement. Cheers!
Coralbut
'72 911T 2.7L
Old 11-20-2004, 03:54 PM
