Send a message via AIM to tkrefeld
Which OIL.....Again??
73.5 T CIS unopened....No leaks....
Michigan winter started every 30 days and oarmed to 180...Summer driven aggressive but not tracked....4K miles p/year
0-40?
0-30?
straigt 30?
15w-50?
10-40?
5-40?
Will probably stick to Dino because of the no leak condition
ect
ect
Old 11-20-2004, 12:36 PM
Heated garage or cold soaked when started in winter? Jim
Old 11-20-2004, 12:43 PM
Carpeted garage (floor only) No heat....Could heat it with the torpedeo but don't plan to to start it
Old 11-20-2004, 01:15 PM
Zeke's Avatar
Well, I would put winter oil in it and then change to summer oil. It sounds expensive, but cars don't like to sit and oil doesn't age gracefully from what I know. At least in a motor started once every 30 days and warmed to 180. That's not enough to boil off the water and I bet you don't run it long enough to evaporate ALL the water at the lower temp.
So, I'm gonna vote for something not on the list. 10/30 winter and 20/50 in the summer. Both dino, of course.
Old 11-20-2004, 01:50 PM
Just put it down for the winter. Do the oil change, add a bit of stabil and maybe fog the motor with fogging oil. Pull the battery and air up the tires. It will be ready and waiting for you in the spring. I do the same with my 911 and Ski Nautique. Check with some boat yards/marinas, some very expensive toys sit all winter without periodic starts and they are fine.
Old 11-20-2004, 02:05 PM
If this is winter oil only and will never see street usage (winter warmups only), maybe a non-syn 5w20 (ford motorcraft branded) may be the winner. I personally would just put in a good 5w40 delvac 1 oil (syn mixed fleet oil- great for aircooled engines) because I don't think it makes leaks "appear" or get any worse, but that's just me :-)
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
Old 11-21-2004, 05:49 AM
5w30 dino oil is my suggestion (provided you change to something heavier - 20W50- in the spring prior to highway driving) to make life easier on the battery when you start it. I would also use fuel stabilizer when you put it to sleep for the winter. Jim
Old 11-21-2004, 06:34 AM
I like regular Rotella T....Am I correct in saying that is a good oil for Spring/summer/fall usage in a Porsche? I run it in heavy equipment w/ good results
Actually, as long as it meets API service specification SL and has the correct multi-viscosity rating I believe the brand is mostly irrelevant. I'm partial to Castrol GTX for my 911 though. Jim
Old 11-21-2004, 06:46 AM
