AN fittings
Can anyone tell me the angle of the flare on "AN" fittings? Is it the same as JIC- 37.5 degrees or SAE 45 degree, or is it something else? Thanks
I think it is the same as JIC fittings. I have a couple # 12 X 30mm adapter fittings if you need some..
Ryan Cimarron region PCA member 98 Boxster |
abit off center
You want your flare to be 37 degrees when using an fittings
Craig
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
