I just acquired a set of Euromeister Turbo Twist 3 Piece 5 Spoke Wheels. They are 8x17's front (positive 28 Offset) and 9x17's rear (positive 15 Offset). I own a 1986 911 Carrera Coupe, Regular Width Body. The worn rubber which currently sits on the wheels is 225/45 on the front, with 8.9" section width and 8.7" tread width. The rears are 255/40's with 10.4" section width, 9.8" tread width. It doesn't seem like there were any width issues with the previous owner of these wheels/tires.
I am looking to potentially upgrade to 235/45's on the front (with 9.2" section width and 8.3" tread width) and on the rear, 265/40's with 10.5" section width and 9.3" tread width. From these numbers, when I compare to the original tires on the wheels, it looks like width shouldn't be too much of an issue, but wanted to ask the experienced masses (as I am a newcomer) whether you had any thoughts on this. I don't really want to roll out the wells if not needed. Any thoughts?! Thanks everyone...this is a great forum! |
Anyone???
I'm fairly new to this forum and I suspect this subject has been discussed at length. I'm just looking for some input as to whether I should go any larger than 225's on the front and whether 265's will actually fit in the rear. Thanks again. |
You'll get some responses, but since it's the Thanksgiving weekend things might be a little slow. If you are in a hurry for an answer do a search for biggest tires narrow car or something. This has come up lots and lots of times. From memory I think you are fine with what you are wanting to go with. I think you could actually go even bigger, but don't quote me on that.
I've got 235/45-17 on a 7.5" wheel and 255/40-17 on a 9" wheel. The 235 is a bit big for the 7.5 so it would be fine an 8" wheel, but I wouldn't go any bigger than 255 on a 9".
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Re: Wheel Width
TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
