How much air flow from heater blower?
I repaired the heater blower motor in the engine compartment, and replaced the relay. The blower now will turn on when I raise the heater levers, but I don't feel much air flow coming out of the vents inside. The blower seems to be strong when pulling off the heater hose. How much air flow should be coming out of the vents with just the heater blower running?
82 911SC
Old 11-21-2004, 08:37 AM
When my footwell blowers were broken I didn't get much, but I also think my rear motor was going bad, so that may not be a good comparison. You'll get more when you rev the motor up.
Old 11-21-2004, 08:44 AM
its a good bit of air. (hows that for a unit of measure?)
that air can be diverted up or down via the lever on the dash... make sure its pointed in the down direction and then check it.
-bernie
Old 11-21-2004, 08:45 AM
Thanks.
The problem must be down by the feet. There is a lot more heat now, but none gets directed to the windshield.
82 911SC
Old 11-21-2004, 09:21 AM
