72&73 guys help !!
I just got the engine to start in my project car for the first time.
Wow it started right up , now I have some questions. I have not driven it yet, just ran it in the drive way.
1. I think I put to much oil because it can out the breather hose.
(10 quarts)
2.The engine has a high idle about 1500 or so how do I fix it?
3. Because I put to much oil will the oil tank leak up at the top, till the oil level is correct or is this wishfull thinking?
4. The engine is smoking a bit, not much I figure the is normal for a engine that sat for 4 years
The engine is a 2.4 MFI from a 73 , the car is a 72
Derek Oxford PCA - Nationally Certified Instructor
2002 Boxster S ( race car)
2010 LR4 2009 GMC Sierra (Porsche Support
2011 M3 4Door
Old 11-20-2004, 08:30 PM
I'd get a turkey baster or something to suck out some oil. That might be part of your smoking problem. To set the idle first set the ignition timing. If you have a vacuum line to the distributor (you should), leave it hooked up to set the idle timing. Set it with the engine hot to the spec. (should be 5 degrees After TDC.). There should be a mark on the pulley there. Once you have the timing set then you can adjust the idle. Make sure the butterflies are closed to the adjustable stops on the throttle bodies. Assuming the butterflies are set correctly you can adjust the air screws on each cylinder to set the idle speed. You really should use a syncronzer to do it right. There is also an idle mixture adjuster on the MFI pump but I wouldn't touch that until the rest is correct.
On my car I found that by setting the timing correctly the idle came down to about 900 RPM.
-Andy
Old 11-21-2004, 07:23 PM
Nitrometano's Avatar
I use 10 qt. of oil in my '72 with no problems. It have no front oil cooler.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 11-21-2004, 07:27 PM
Author of "101 Projects"
Wayne 962's Avatar
It all depends upon how much you remove. My system can probably hold 12-13 quarts as it has a front bumper mounted cooler...
-Wayne
Old 11-22-2004, 01:59 AM
