Using 964 Tip motor for conversion
I have a line on a 964 Tip motor. I was wondering what will have to be done if this motor is used for a conversion into a SC based car. I know the flywheel will have to be changed anyway, but what about the control units and electronics?
Thanks |
instant-g.com, there should be the info there you can read, Kevin
Instant-G had little or no info on using a tip. Anyone?
The only issue and it's not a big one, is the lack of a reverse light circuit in a tip harness. The tip uses a switch from the shifter. So you need to figure a way to trugger that circuit. Steve T. does know how to do it.
hmmm, mine don't work anyway!
| All times are GMT -8. The time now is 03:58 AM. |
