randywebb's Avatar
myster hose in trunk
Does anybody know what the fabric covered hose is for in the front trunk in this photo? It is not connected, is about 3/8" dia. and goes thru the grommet behind that wire bundle into the fender somewhere.
This is a '73/5 so it did have CIS.
ALso, note the lack of grommets on the other two hoses -- do people with unmolested cars have grommets there?
Thanks.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-27-2004, 01:21 PM
Looks like the same type of hose used for the brake fluid resevoir vent.
gary
Old 11-27-2004, 01:30 PM
Part of vapor recovery system. Small line had a grommet (item 16 below) around it at wheel case penetration; large line connected to a tube (item 37 below) that was welded to and passed through the wheel case. Brake fluid reservoir vent/overflow drain was through bottom of front trunk just behind front bumper. See the below figure. Jim
Old 11-27-2004, 01:42 PM
randywebb's Avatar
Thx. I'll have to see what parts of the evap. system are left on this car. I know it has item 2 and is missing the charcoal cylinder.
Noah, they are hoses, but I take your point.
Old 11-27-2004, 03:02 PM
