| Registered Join Date: Mar 2004 Location: Snohomish, Wa
				What cams are these?
			Happy Thanksgiving everyone! . I bought these cams awhile back and was told they where E cams. But Iam not sure #s are901 105 109 01. they are a Delta regrind and stamped on the ends are PC224 and PC218. condition seems good but are a little pited here and there but should clean up with alittle polishing. The thought was they could be SC grind but I trust someone here would know.I would Like to trade them for  tall weber intake manafolds if the cams are worth any thing. thanks Chuck.
|  11-25-2004, 09:48 AM |
| Registered Join Date: Feb 2004 Location: California
			I do not recognize the PC224 or PC218 numbers, but the casting numbers are for an early E or solex cam. There might be an 05 stamped on the front of the cam. the 05 makes it an E.  Unless it has been hardwelded the SC profile would not fit this casting as a regrind.
				__________________ John Dougherty Dougherty Racing Cams | ||
|  11-25-2004, 10:08 AM |
			Thanks John didnt see a 05# is there a measurement i could take of the lobes to see if they are in deed Solex or something else?
|  11-25-2004, 10:27 AM |
			If you measure the intake lobe lift, an E cam will have .275" +/- and the solex will have .305" +/- the exhausts are both in the .275" .280" range
				__________________ John Dougherty Dougherty Racing Cams Last edited by camgrinder; 11-25-2004 at 11:21 AM.. | ||
|  11-25-2004, 11:02 AM |
			Thanks for the info any idea what I should Ebay them for?
|  11-25-2004, 11:57 AM |
