locktite?
Should locktite be used on the tensioner mounting studs/nuts or is just the nut and washer torqued to spec, OK?
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Irrationally exuberant
If it's the one I'm thinking of, that nut has a wavey washer under it i.e. a lock washer. That should take care of that fastener.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
I think I used loctite blue.. although I've never read that it's necessary.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Thats what I am planning on using when I get that far.
