915 upgrades
Surgery is necessary on my 915 trans. While in there replacing worn synchros...any experiences with gear changes for closer ratios, LSD, WEVO gate shifts or any other potentially expensive maneuvers? Oh yeah, this 1975 911S has a 3.6L varioram with lghtwgt flywheel-centerforce clutch...plenty of torque already! Thanks for your inputs. NKG
911S/GTS4 964 C4 1987 Carrera 3.2 |
one thing you should do is update the 3 arm hubs to the later style which are beefier. (that 3.6 could break one of the wimpy arms off). requires the later shift sleeves to match. then 1st syncro teeth need to be changed to the later assymetrical style to match the new shift sleeve, along with the later 1st brake band. 2nd gear should also get the later brake band. with the early 7:31 diff, (if you have it), the ratios should already be pretty close. a 0.72 5th would keep the Rs down on the freeway and save gas, if you care.
I recently had the same opportunity, and I decided to do the ZF LSD, wevo gate shift, wevo shifter, and new shift joint. All in at about 6K including rebuild.
This is on a track only car and the difference is incredible. If yours is a street car, I'd skip the wevo stuff. Since you hace a 3.6 in it the LSD may still be a good idea, if for no other reason than to save a little rear rubber. I wanted to add a cooler, but ran out of $.
Mark H Class Race Car Project Old flames: 1999 C2 Race Car #78; 1983 SC Race Car; #78; 1990 C2; 1978 SC Race Car #78; 1988 Carrera; 1977 911S |
On a similar note, I thought the mag trannies were not recommended for 3.6 conversions. My '72 mag tranny is supposed to be the weakest. It will be replaced.
- '72 911T - '81 911SC Euro |
Me like track days
Lower 3rd gear --- the huge spacing between 2nd and 3rd is assinine -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
