Correct Wire Diag.
Does anyone have a a source of a correct '77 911s wire diagram for the headlights, with colors for the wires? I checked the '73 diagram that is here and my wires are a differnt color in some cases. Also the is a "jumper" on the diagram that I don't have. It's between fuse 1 and 2 also 3 and 4. Is there a source for these? Thanks
Porsche crazy now have a 1994 325i also
Old 11-28-2004, 06:37 PM
There is a useable wiring diagram for 1977 in the Haynes repair manual. In 1977 fuse position one isn't used; fuse positions 5, 6, 7 and 8 are used for the headlights. In 1977 fuse positions 5 to 6 and 7 to 8 are hard linked (jumpered) together respectively. The "hard links" are usually an integral part of the fuse block. In 1977, the high beams run off fuses 7 (right headlight- white and blue wire) and 8 (left headlight - blue wire); the low beams run off fuses 5 (right headlight - yellow wire) and 6 (left headlight - green and yellow wire). Cheers, Jim
Old 11-28-2004, 07:55 PM
wire diagram
Thanks Jim!! The Haynes that I have is not even close to my wires. I think that at some point the car was rewired. I am going to try the colors taht you sent me and see if that works. Thanks again-----Bob
Old 11-28-2004, 09:10 PM
wire diagram
Jim I forgot to ask. The " hard links " are not there. Does that mean that I have to replace the whole fuse block or can the be made up some other way? Also my #1 fuse is being used for something. Not sure what.
Old 11-28-2004, 09:15 PM
randywebb's Avatar
re last query:
This usually means a PO has been at work. You may have to trace the wires to find out what is going on. Do the wires from it look non-factory?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-28-2004, 10:16 PM
No they look to factory. Color and color strip. I don't think you can even find the color combo's that are in these cars anymore---Bob
Old 11-28-2004, 10:30 PM
randywebb's Avatar
Hmmm, if so, then why is there a fuse there? Or maybe you have some option that JS was not aware of in his post above?
Old 11-28-2004, 10:59 PM
The only option that I have is the after market a/c that hangs under the dash. The comp. etc is gone from the back only the hoses are still there.
The is also ( up front ) a 2 pin circuit-breaker all taped up. ----Bob
Old 11-28-2004, 11:08 PM
