-   -   Intermittent NO START, and fail running (http://forums.pelicanparts.com/porsche-911-technical-forum/194400-intermittent-no-start-fail-running.html)
nhromyak 12-01-2004 09:24 PM
As far as the Bentley is concerned, the sensors check out with ohm resistance too (sort of).
Bentley says Terminals 1 & 2 should be 960 ohm +/- 96 ohms.
One sensor is 956 ohms, the other is at 1110 (too high?)
Bentely says Terminals 1 & 3 and 2 & 3 should be > 100k ohms. Both sensors and both sets of terminals are OPEN. ???
This is greater than 100K ohms though... right?
Looking in the Bentely and in my Haynes, I don't see an Ohm measurements between 1 and 15 and 4 and 15 for the coil.
Even though the Bentley specifically says to check for resistance, they don't say how much. It does say to reference Table B.
Table B refers to the Speed and Reference Sensor ohm resistances. See above.
I got 5.6K ohms between 4 & 15 (HT and + coil)
I got 0.6 ohms between 1 & 15 terminals (LT - and + of coil).
Are these coil resistance values OK?
I found the fuel leak. It's a small leak, could this be my pulsing and rich running idle?
It's simple turn of the screwdriver, if I can get my screwdriver back there.
Thanks again for everyone's replies.
nhromyak 12-02-2004 11:11 PM
It looks like my harness is not getting the AFM voltages on pin 22.
But then again, I need to look at the harness diagram. I think the computer is supposed to provide the 5 volts. Can anyone confirm? I checked pin 22 with the computer disconnected, I suppose I can take the harness out and check the wire with the computer connected... ???
It also appears my high altitude switch is not providing a ground to the DME. I will be pursuing that one tomorrow.
Any other tips while checking the DME and the connectors at this level?
Thanks.
rick-l 12-03-2004 09:15 AM
The voltage (4.3volts) comes from the DME so if the connector was disconected you would not see it.
nhromyak 12-03-2004 03:01 PM
Thanks for the reply. I was wondering how it could get 0 - 5 volts without the DME, or something.. :D
Would the high altitude switch give me these weird ignition or rich fuel problems?
From what I have read on www.systemsc.com, it's still pointing to a DME issue. :(
Model 911 (Motronic 3rd) - 0 261 200 XXX
intermittent running, no ignition spark, excessive fuel floods engine
midlife 12-03-2004 05:23 PM
Nick,
Sorry, I don't have any answers to offer you, but I did want to thank you for the updates. I purchased a 944 recently that was real cheep due to a similar intermittent problem. It would occasionally run so rich that it would barely run. The trouble (or good thing) is that it has not done it since the day I looked at the car. It is hard to fix if you can't catch it in the act.
I'm hoping when you fix yours, I will have another possible thing to check. Now with three Motronic cars, I need to learn these systems.
One other thing is that the 944 acts like the cat could be plugged, which is not surprising due to rich running.
Mike
