-   -   MFI stacks for Electronic injection ? (http://forums.pelicanparts.com/porsche-911-technical-forum/194453-mfi-stacks-electronic-injection.html)
jmz 11-29-2004 03:12 PM
I am sick of carbs and will most likely be converting to EFI.
Has anyone used MFI throttle bodies w/ motec or tec III ???
I would like some input on wether this is a somewhat reasonable idea.
jpnovak 11-29-2004 03:16 PM
You should be able to mount MFI stacks ontop of some injector blocks. The injector blocks are still pricey. Fitting the injectors will allow you to choose any EFI system.
CamB has an EFI system based on MFI intakes. I have not seen him post in a while. You can search for his system in the archives.
TimT 11-29-2004 04:39 PM
A few years ago I saw a guy at the track that had MFI manifolds machined to accept electronic injectors, and gutted weber carbs acting as tbs....MoTec M$ managed.. car went like stink..
btw 37'Alberg... way cool
