Question oil pressure
I was wondering what the typical oil pressure was for a 2.7 liter?
I have a 74' 911, it has a oil cooler, and runs good, but I am thinking about a rebuild. The oil pressure is fine when your running down the highway, but really low at idle. Is this normal?
1974 911 Coupe 2.7
1973 AMC Hornet X 360ci
1988 Toyota 4 Runner
1981 Chevy C-10 SWB
2009 Chevy Z71 DD
Old 11-29-2004, 10:51 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
The typical oil pressure rule of thumb is 10-14psi (1 bar) per 1000 rpms. Many engines show near 0 oil pressure at idle though which is ok as long as you've got good oil pressure when the engine is reved. Also make sure your oil light does not light up at idle.
There is a new oil cam adapter that bumps the idle oil pressure up by about 10 psi. I'm not sure of the part number but do a search and you'll find it.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 11-29-2004, 11:49 AM
And those pressures are when the engine is hot. It'll be much higher when the engine and oil is cold, probably double that or more.
Old 11-29-2004, 12:13 PM
yeah, when its cold it is much, much higher. Thank you for the advice. I will definately look into the oil cam adapter. The reason why I am inquiring about this is because I am thinking about rebuilding the top-end, and I can't decide if I should just rebuild the entire motor.
1974 911 Coupe 2.7
1981 Chevy C-10 SWB
2009 Chevy Z71 DD
Old 11-29-2004, 02:49 PM
Send a message via AIM to tkrefeld
Is 180 hot?
Old 11-29-2004, 05:06 PM
autoxracer31's Avatar
Send a message via AIM to autoxracer31
my old 2.7 ran very oddly. The pressure would be at about 10 at idle and wouldnt exceed 40 on max rpm. Never knew why. Neither did my mechanic. He thought the springs in the motor that control pressure were installed incorrectly but before we figured it out, one of the pistons broke.
Not really helpful but is a story for me to tell
Old 11-29-2004, 07:33 PM
Jeff Alton's Avatar
The factory spec is 4 bar (about 59lbs) at 5000rpm with the engine at operating temp.
Jeff
www.turn3autosport.com
Old 11-29-2004, 09:36 PM
Designer King
Paulporsche's Avatar
tkrefeld:
180 is just barely warmed up.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-30-2004, 07:21 AM
Yeah, mine runs between 180 and about 210. Where it's suppose to i guess. I have like lots anf lots of pressure at 180, like about 60 or a little more at 3 or 4,000 rpm, its just a little low at idle. but the low oil pressure light doesn't come on, so i think i'm ok.
1974 911 Coupe 2.7
1981 Chevy C-10 SWB
2009 Chevy Z71 DD
Old 11-30-2004, 10:26 AM
